We have several questions regarding the relationship between linux system time vs. TSC vs. RTC.
Our observations based on the attached script are as follows:
It seems that linux system time is completely independent from
TSC time. Are TSC clock values used to calculate the system time? -
The RTC looks like it is pretty exactly 500ms off even after sync. Is that on purpose or is there some error somewhere?
What clock is used to calculate linux system time? If it would use TSC is there a formula and what are the parameters?
The manual states that the TSC clock should run at 31.25Mhz. However, in our experiments the least drift between linux system time and the clock was at 31.249Mhz. Is that the expected accuracy of the clock or is there something else wrong?
You should be able to replicate the experiments on your Xavier with the attached script.
Run as follows:
sudo watch -n .1 ./test.sh
Script test.sh
#/bin/bash
#get all the times
#read rtc via registers (not via date)
#first read millisecs. This causes update of shadow secs. Read those next
#read shadow secs
rtcdmsec1=$(printf "%d\n" $(busybox devmem 0x0c2a0010 W))
rtcdsec1=$(printf "%d\n" $(busybox devmem 0x0c2a000c W))
#Read higher bits
list2=$(busybox devmem 0x03010004 W)
#read lower bits andrtc
nsecsrtc1=$(date +%s%N)
list=$(busybox devmem 0x03010000 W)
nsecsrtc2=$(date +%s%N)
rtcdmsec2=$(printf "%d\n" $(busybox devmem 0x0c2a0010 W))
rtcdsec2=$(printf "%d\n" $(busybox devmem 0x0c2a000c W))
#Convert time to RTC
rtctime1=$(echo "($rtcdsec1 * 1000 + $rtcdmsec1)" | bc)
rtctime2=$(echo "($rtcdsec2 * 1000 + $rtcdmsec2)" | bc)
rtctime=$(echo "($rtctime1 + $rtctime2)/2" |bc)
rtctimesec=$(echo "$rtctime/1000" | bc)
#average to account for scheduling and other delays
nsecsrtc=$(echo "($nsecsrtc1+$nsecsrtc2)/2" | bc)
rtcdiff=$(echo "$rtctime - $nsecsrtc/1000000" | bc)
convs=$(printf "%d\n" $list)
convs2=$(printf "%d\n" $list2)
#shift over bits
higherbits=$(echo $(($convs2<<32)))
decn=$(echo "($higherbits + $convs)/31.249" |bc)
secs=$(echo "$decn/1000000.0" | bc)
secsrtc=$(echo "$nsecsrtc/1000000000" |bc)
delta=$(echo "(-($decn-$nsecsrtc/1000))"|bc)
deltams=$(echo "($delta/1000)"|bc)
systimems=$(echo "$nsecsrtc / 1000000" | bc)
echo "Difference between TKE_AON_SHARED_TKETSC0_0 /31.249 (is supposed to be 31.25) and linux clock."
echo "RTC Direct time (millisec): $rtctime\t (secs) $rtctimesec"
echo "System time (millisec): $systimems\t (secs) $secsrtc"
echo "Theoretically RTC and system time could line up but typically they can be quite different"
echo "System time vs. RTC diff (millisec): $rtcdiff"
echo "TSC:Microsecs: $decn\t Secs: $secs \n"
echo "Difference between the system time and TSC:\nDelta (Microsec): $delta\tMillisecs $deltams"
Expected output:
Every 0.1s: ./test.sh xavier: Tue Sep 3 17:49:11 2019
d linux clock.
RTC Direct time (millisec): 1567547351668 (secs) 1567547351
System time (millisec): 1567547351186 (secs) 1567547351
different
System time vs. RTC diff (millisec): 482
TSC:Microsecs: 239245444392 Secs: 239245
Delta (Microsec): 1567308105742004 Millisecs 1567308105742
