I’m trying to create an exact copy of one Orin AGX to another. I’ve copied the SSDs by mounting them both on a host PC and then using dd to clone all partitions.
Is there an equivalent operation to clone the EMMC memory?
Thank You!
Johann
Thank You!
Johann
We have a tool for this:
https://docs.nvidia.com/jetson/archives/r36.3/DeveloperGuide/SD/FlashingSupport.html#backing-up-and-restoring-a-jetson-device
Hi Dave
Thank you, this is exactly what i’m looking for.
I’m not quite shure how to use it though. What I did was:
Using the SDK manager create the Linux_for_Tegra directory. Then, with the Jetson in the recovery mode, I called
~/Downloads/nvidia/sdkm_downloads/Jetson_Linux_R35.4.1_aarch64/Linux_for_Tegra$ sudo ./tools/backup_restore/l4t_backup_restore.sh -e mmcblk0p2 -r jetson-agx-orin-devkit
Then it failed with the below errors.
Is that the intended usage?
Thank You
Johann
failingBackup.txt (55.2 KB)
somewhere in the forums I found this command:
sudo ./flash.sh -r -k APP -G backup.img jetson jetson-agx-orin-devkit mmcblk0p1
but this fails with this error:
secondAttempt.txt (21.1 KB)
Your BSP folder is corrupted.
Please delete everything and try again.
You backup with
sudo ./tools/backup_restore/l4t_backup_restore.sh -e mmcblk0 -b jetson-agx-orin-devkit
, and you restore with
sudo ./tools/backup_restore/l4t_backup_restore.sh -e mmcblk0 -r jetson-agx-orin-devkit
I don’t know how you came up with the idea of using mmcblk0p2
