Cloning issue with the AI Workbench Tutorial
Hello
I just received my Spark. I wanted to test the ‘RAG Application in AI Workbench’ playbook. After installing the ‘NVIDIA AI Workbench’ software, I see "Clone the AI Workbench Tutorial, Learn the basic fundamentals of a project, how to use applications and more”.
When I click on ‘Get Started’, I get the error ‘Attempt to clone project to current location encountered an error, review the location’s service logs to determine the error’. I can’t understand why. I tried cloning it from Spark and from a remote machine :-(
Have you tried cloning this project? Thank you for your help
I have the same problem. After configuration I am trying to add “Get started” Tutorial but i have the same error of stealthbull74.
Where are this service logs?
Fulvio
Hi, do you have this issue with just the tutorial or with any project you try to clone?
Bonjour j’ai le même problème!!
Cordialement
Mathieu
Hello
I also have the same Problem on my ASUS GX10:
Log:
git clone GitHub - NVIDIA/workbench-example-onboarding-project: An interactive tutorial project that demonstrates the capabilities of NVIDIA AI Workbench testclone
Klone nach ‘testclone’…
remote: Enumerating objects: 208, done.
remote: Counting objects: 100% (101/101), done.
remote: Compressing objects: 100% (44/44), done.
remote: Total 208 (delta 75), reused 57 (delta 57), pack-reused 107 (from 1)
Empfange Objekte: 100% (208/208), 4.15 MiB | 9.85 MiB/s, fertig.
Löse Unterschiede auf: 100% (87/87), fertig.
Schwerwiegend: mehrere Aktualisierungen für Referenz ‘refs/remotes/origin/main’ nicht erlaubt
