Dear team,
I managed to flash the tk1 multiple times successfully, however now that the project is completed I would
like to have a copy of my system. When I try to flash it, using the following command, it gets stuck.
~/JetPackTK1-1.2/Linux_for_Tegra/bootloader$ sudo ./nvflash --read 12 system.img --bl fastboot.bin --go
Nvflash 4.13.0000 started
BR_CID: 0x34001001740de1001c0000000c060480
rcm version 0X400001
System Information:
chip name: unknown
chip id: 0x40 major: 1 minor: 1
chip sku: 0x0
chip uid: 0x00000001740de1001c0000000c060480
macrovision: disabled
hdcp: disabled
jtag: disabled
sbk burned: false
board id: 0
warranty fuse: 0
dk burned: false
boot device: emmc
operating mode: 3
device config strap: 0
device config fuse: 0
sdram config strap: 0
RCM communication completed
downloading bootloader – load address: 0x83d88000 entry point: 0x83d88000
sending file: fastboot.bin
- 594363/594363 bytes sent
fastboot.bin sent successfully
waiting for bootloader to initialize
I’m using a short usb cable.
Update: after waiting a while, I received the following error:
usb read error (32): Broken pipe
bootloader failed NvError 0x0
command failure/warning: bootloader download failed
