Cloud GPU compatibility with CUDA 8/10
Is there a Cloud GPU product or service that is compatible with CUDA 8 or CUDA 10 drivers? The main reason I am asking this is because I was wondering if a program that I am running locally can be run through a Cloud platform. The program I am running requires certain specifications such as (GTX 1060, RTX 2060), but since Cloud GPUs offer products such as TESLAs I was curious to see if I could run my program on the cloud using a Cloud GPU that can work with the required specifications.
If the above question cannot be answered, I was wondering if you could answer these questions:
  1. Is there a Cloud GPU that is compatible with CUDA 8 and CUDA 10?
  2. Is it possible to run an application program on the Cloud disregarding the Cloud GPU?
  3. If a certain program that has certain hardware specifications (GPU-specs), but the Cloud GPU covers all these requirements, does this mean that I will be able to run this program on any computer or laptop without having to worry about GPUs?
Thank you and I hope to hear from you soon.
