I am working on a Unity plugin for the new architecture. It works on non-secure mode. But the runtime fails to load certificates if I pass their paths. The logs show:
(E)\[2026-05-01 13:43:10,330\]=16:43:10=*00000*{224700} Failed to start signaling server: 'I/O error: Failed to load certificate from stream'
Certs are geneated using:
openssl req -x509 -newkey rsa:4096 -nodes \
-keyout key.pem -out cert.pem -days 365 -sha256 \
-subj "/CN=localhost" \
-addext "basicConstraints=CA:FALSE" \
-addext "keyUsage=digitalSignature,keyEncipherment" \
-addext "extendedKeyUsage=serverAuth" \
-addext "subjectAltName=DNS:localhost,IP:127.0.0.1"
I supply the paths as string parameters:
"D:\\certs\\cert.pem"
"D:\\certs\\key.pem";
if (!certPemPath.empty() && !keyPemPath.empty())
const char *kCertProp = "certificate-pem";
auto certLen = (uint32_t)strlen(certPemPath.c_str());
r = pfnSetString_(service_, kCertProp, strlen(kCertProp), certPemPath.c_str(), certLen);
if (r != NV_CXR_SUCCESS)
LOG_ERROR("set certificate-pem failed: %d", r);
pfnDestroy_(service_);
service_ = nullptr;
FreeLibrary(dllHandle_);
dllHandle_ = nullptr;
return false;
LOG_INFO("certificate-pem path set: %s", certPemPath.c_str());
const char *kKeyProp = "key-pem";
auto keyLen = (uint32_t)strlen(keyPemPath.c_str());
r = pfnSetString_(service_, kKeyProp, strlen(kKeyProp), keyPemPath.c_str(), keyLen);
LOG_ERROR("set key-pem failed: %d", r);
service_ = nullptr;
return false;
LOG_INFO("key-pem path set: %s", keyPemPath.c_str());
