I am compiling cpp and cu codes together using this command :
add_executable(objects_detection “./objects_detection.cpp”) .
all libraries are added then linked and it compiles well (without atomic functions) but showing this warning:
nvcc warning : The ‘compute_10’ and ‘sm_10’ architectures are deprecated, and may be removed in a future release.
Having compute_10 code generated I cannot compile cuda atomic functions.
I added both of these code lines separately and also together to cmake but I still get the same warning and it throws error when I comment out the atomic function (atomicAdd())
list(APPEND CUDA_NVCC_FLAGS “-gencode=arch=compute_20,code=sm_20”)
set(CUDA_NVCC_FLAGS ${CUDA_NVCC_FLAGS} -arch compute_20 -code sm_20)
any help or hint would be appreciated
thank you
