CMAKE OpenCV CUDA module, nvcc error : '""%CICC_PATH%\cicc"' died with status 0xC0000005 (ACCESS_VIOLATION)
I was going to open a vcpkg bug, but all signs point to an issue with the compiler. I’ve tried multiple versions of CUDA 12.8, all to the same conclusion. My project has cuda source files, and they compile just fine (I can build opencv without cuda support and everything works as expected).
I can provide the memory dump files if needed
nvidia-smi
Tue Apr  1 09:04:43 2025
| NVIDIA-SMI 572.61                 Driver Version: 572.61         CUDA Version: 12.8     |
| GPU  Name                  Driver-Model | Bus-Id          Disp.A | Volatile Uncorr. ECC |
|   0  NVIDIA RTX 3000 Ada Gene...  WDDM  |   00000000:01:00.0 Off |                  Off |
| N/A   46C    P8              6W /   59W |      73MiB /   8188MiB |     26%      Default |
|                                         |                        |                  N/A |
nvcc --version
Copyright (c) 2005-2025 NVIDIA Corporation
Built on Fri_Feb_21_20:42:46_Pacific_Standard_Time_2025
Cuda compilation tools, release 12.8, V12.8.93
Build cuda_12.8.r12.8/compiler.35583870_0
stereobm.cu
Package: opencv4[calib3d,contrib,core,cuda,default-features,dnn,dshow,fs,gapi,highgui,intrinsics,jpeg,png,quirc,thread,tiff,webp,win32ui]:x64-windows@4.10.0#3
Host Environment
  • Host: x64-windows
  • Compiler: MSVC 19.42.34438.0
  • vcpkg-tool version: 2025-01-11-0f310537c75015100d200eb71b137f6376aad510
    vcpkg-scripts version: 4f8fe05871 2025-03-31 (16 hours ago)
To Reproduce
vcpkg install
C:\Development\vcpkg\buildtrees\opencv4\install-x64-windows-dbg-out.log
Change Dir: 'C:/Development/vcpkg/buildtrees/opencv4/x64-windows-dbg'
Run Build Command(s): "C:/Program Files/Microsoft Visual Studio/2022/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/Ninja/ninja.exe" -v -v -j23 install
[1/1352] C:/PROGRA~1/CMake/bin/cmcldeps.exe RC C:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg\modules\cudev\vs_version.rc modules\cudev\CMakeFiles\opencv_cudev.dir\vs_version.rc.res.d modules\cudev\CMakeFiles\opencv_cudev.dir\vs_version.rc.res "Note: including file: " "C:/Program Files/Microsoft Visual Studio/2022/Professional/VC/Tools/MSVC/14.42.34433/bin/Hostx64/x64/cl.exe" C:\PROGRA~2\WI3CF2~1\10\bin\100226~1.0\x64\rc.exe -DCVAPI_EXPORTS -D_USE_MATH_DEFINES -D_VARIADIC_MAX=10 -D_WIN32_WINNT=0x0601 -D__OPENCV_BUILD=1 -D__STDC_CONSTANT_MACROS -D__STDC_FORMAT_MACROS -D__STDC_LIMIT_MACROS -I C:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudev\src -I C:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudev\include -I C:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg\modules\cudev -I C:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\include -I C:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg -c65001 /DWIN32 -D_DEBUG /fo modules\cudev\CMakeFiles\opencv_cudev.dir\vs_version.rc.res C:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg\modules\cudev\vs_version.rc
[2/1352] C:\PROGRA~1\MICROS~1\2022\PROFES~1\VC\Tools\MSVC\1442~1.344\bin\Hostx64\x64\cl.exe   /TP -DCVAPI_EXPORTS -D_USE_MATH_DEFINES -D_VARIADIC_MAX=10 -D_WIN32_WINNT=0x0601 -D__OPENCV_BUILD=1 -D__STDC_CONSTANT_MACROS -D__STDC_FORMAT_MACROS -D__STDC_LIMIT_MACROS -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudev\src -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudev\include -IC:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg\modules\cudev -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\include -external:IC:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg -external:W0 /nologo /DWIN32 /D_WINDOWS /utf-8 /GR /MP   /D _CRT_SECURE_NO_DEPRECATE /D _CRT_NONSTDC_NO_DEPRECATE /D _SCL_SECURE_NO_WARNINGS /Gy /bigobj /Oi  /fp:precise /FS     /EHa /wd4127 /wd4251 /wd4324 /wd4275 /wd4512 /wd4589 /wd4819 /wd4189 /wd4505  /MDd /Z7 /Ob0 /Od /RTC1   -std:c++17 -MDd /showIncludes /Fomodules\cudev\CMakeFiles\opencv_cudev.dir\src\stub.cpp.obj /Fdlib\opencv_cudev4d.pdb /FS -c C:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudev\src\stub.cpp
[3/1352] C:\WINDOWS\system32\cmd.exe /C "cd . && "C:\Program Files\CMake\bin\cmake.exe" -E vs_link_dll --msvc-ver=1942 --intdir=modules\cudev\CMakeFiles\opencv_cudev.dir --rc=C:\PROGRA~2\WI3CF2~1\10\bin\100226~1.0\x64\rc.exe --mt=C:\PROGRA~2\WI3CF2~1\10\bin\100226~1.0\x64\mt.exe --manifests  -- C:\PROGRA~1\MICROS~1\2022\PROFES~1\VC\Tools\MSVC\1442~1.344\bin\Hostx64\x64\link.exe  modules\cudev\CMakeFiles\opencv_cudev.dir\src\stub.cpp.obj modules\cudev\CMakeFiles\opencv_cudev.dir\vs_version.rc.res  /out:bin\opencv_cudev4d.dll /implib:lib\opencv_cudev4d.lib /pdb:bin\opencv_cudev4d.pdb /dll /version:4.10 /machine:x64  /nologo    /debug /INCREMENTAL  /NODEFAULTLIB:libc /DEBUG  kernel32.lib user32.lib gdi32.lib winspool.lib shell32.lib ole32.lib oleaut32.lib uuid.lib comdlg32.lib advapi32.lib && cd ."
[4/1352] C:\WINDOWS\system32\cmd.exe /C "cd /D C:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg\modules\core && "C:\Program Files\CMake\bin\cmake.exe" -DMODULE_NAME=core -DCL_DIR=C:/Development/vcpkg/buildtrees/opencv4/src/4.10.0-db32e53cd3.clean/modules/core/src/opencl -DOUTPUT=C:/Development/vcpkg/buildtrees/opencv4/x64-windows-dbg/modules/core/opencl_kernels_core.cpp -P C:/Development/vcpkg/buildtrees/opencv4/src/4.10.0-db32e53cd3.clean/cmake/cl2cpp.cmake"
[5/1352] C:\PROGRA~1\MICROS~1\2022\PROFES~1\VC\Tools\MSVC\1442~1.344\bin\Hostx64\x64\cl.exe   /TP -DCVAPI_EXPORTS -DOPENCV_ALLOCATOR_STATS_COUNTER_TYPE="long long" -D_USE_MATH_DEFINES -D_VARIADIC_MAX=10 -D_WIN32_WINNT=0x0601 -D__OPENCV_BUILD=1 -D__STDC_CONSTANT_MACROS -D__STDC_FORMAT_MACROS -D__STDC_LIMIT_MACROS -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\src -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\include -IC:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg\modules\core -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudev\include -IC:\Development\AE.AI\build\vcpkg_installed\x64-windows\include -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.8\include" -external:IC:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg -external:W0 /nologo /DWIN32 /D_WINDOWS /utf-8 /GR /MP   /D _CRT_SECURE_NO_DEPRECATE /D _CRT_NONSTDC_NO_DEPRECATE /D _SCL_SECURE_NO_WARNINGS /Gy /bigobj /Oi  /fp:precise /FS     /EHa /wd4127 /wd4251 /wd4324 /wd4275 /wd4512 /wd4589 /wd4819  /MDd /Z7 /Ob0 /Od /RTC1   -std:c++17 -MDd /showIncludes /Fomodules\core\CMakeFiles\opencv_core.dir\src\buffer_area.cpp.obj /Fdlib\opencv_core4d.pdb /FS -c C:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\src\buffer_area.cpp
[6/1352] C:\PROGRA~1\MICROS~1\2022\PROFES~1\VC\Tools\MSVC\1442~1.344\bin\Hostx64\x64\cl.exe   /TP -DCVAPI_EXPORTS -DOPENCV_ALLOCATOR_STATS_COUNTER_TYPE="long long" -D_USE_MATH_DEFINES -D_VARIADIC_MAX=10 -D_WIN32_WINNT=0x0601 -D__OPENCV_BUILD=1 -D__STDC_CONSTANT_MACROS -D__STDC_FORMAT_MACROS -D__STDC_LIMIT_MACROS -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\src -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\include -IC:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg\modules\core -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudev\include -IC:\Development\AE.AI\build\vcpkg_installed\x64-windows\include -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.8\include" -external:IC:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg -external:W0 /nologo /DWIN32 /D_WINDOWS /utf-8 /GR /MP   /D _CRT_SECURE_NO_DEPRECATE /D _CRT_NONSTDC_NO_DEPRECATE /D _SCL_SECURE_NO_WARNINGS /Gy /bigobj /Oi  /fp:precise /FS     /EHa /wd4127 /wd4251 /wd4324 /wd4275 /wd4512 /wd4589 /wd4819  /MDd /Z7 /Ob0 /Od /RTC1   -std:c++17 -MDd /showIncludes /Fomodules\core\CMakeFiles\opencv_core.dir\src\channels.cpp.obj /Fdlib\opencv_core4d.pdb /FS -c C:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\src\channels.cpp
[7/1352] C:\PROGRA~1\MICROS~1\2022\PROFES~1\VC\Tools\MSVC\1442~1.344\bin\Hostx64\x64\cl.exe   /TP -DCVAPI_EXPORTS -DOPENCV_ALLOCATOR_STATS_COUNTER_TYPE="long long" -D_USE_MATH_DEFINES -D_VARIADIC_MAX=10 -D_WIN32_WINNT=0x0601 -D__OPENCV_BUILD=1 -D__STDC_CONSTANT_MACROS -D__STDC_FORMAT_MACROS -D__STDC_LIMIT_MACROS -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\src -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\include -IC:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg\modules\core -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudev\include -IC:\Development\AE.AI\build\vcpkg_installed\x64-windows\include -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.8\include" -external:IC:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg -external:W0 /nologo /DWIN32 /D_WINDOWS /utf-8 /GR /MP   /D _CRT_SECURE_NO_DEPRECATE /D _CRT_NONSTDC_NO_DEPRECATE /D _SCL_SECURE_NO_WARNINGS /Gy /bigobj /Oi  /fp:precise /FS     /EHa /wd4127 /wd4251 /wd4324 /wd4275 /wd4512 /wd4589 /wd4819  /MDd /Z7 /Ob0 /Od /RTC1   -std:c++17 -MDd /showIncludes /Fomodules\core\CMakeFiles\opencv_core.dir\src\cuda_gpu_mat_nd.cpp.obj /Fdlib\opencv_core4d.pdb /FS -c C:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\src\cuda_gpu_mat_nd.cpp
[8/1352] C:\PROGRA~1\MICROS~1\2022\PROFES~1\VC\Tools\MSVC\1442~1.344\bin\Hostx64\x64\cl.exe   /TP -DCVAPI_EXPORTS -DOPENCV_ALLOCATOR_STATS_COUNTER_TYPE="long long" -D_USE_MATH_DEFINES -D_VARIADIC_MAX=10 -D_WIN32_WINNT=0x0601 -D__OPENCV_BUILD=1 -D__STDC_CONSTANT_MACROS -D__STDC_FORMAT_MACROS -D__STDC_LIMIT_MACROS -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\src -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\include -IC:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg\modules\core -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudev\include -IC:\Development\AE.AI\build\vcpkg_installed\x64-windows\include -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.8\include" -external:IC:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg -external:W0 /nologo /DWIN32 /D_WINDOWS /utf-8 /GR /MP   /D _CRT_SECURE_NO_DEPRECATE /D _CRT_NONSTDC_NO_DEPRECATE /D _SCL_SECURE_NO_WARNINGS /Gy /bigobj /Oi  /fp:precise /FS     /EHa /wd4127 /wd4251 /wd4324 /wd4275 /wd4512 /wd4589 /wd4819  /MDd /Z7 /Ob0 /Od /RTC1   -std:c++17 -MDd /showIncludes /Fomodules\core\CMakeFiles\opencv_core.dir\src\count_non_zero.dispatch.cpp.obj /Fdlib\opencv_core4d.pdb /FS -c C:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\src\count_non_zero.dispatch.cpp
[9/1352] C:\PROGRA~1\MICROS~1\2022\PROFES~1\VC\Tools\MSVC\1442~1.344\bin\Hostx64\x64\cl.exe   /TP -DCVAPI_EXPORTS -DOPENCV_ALLOCATOR_STATS_COUNTER_TYPE="long long" -D_USE_MATH_DEFINES -D_VARIADIC_MAX=10 -D_WIN32_WINNT=0x0601 -D__OPENCV_BUILD=1 -D__STDC_CONSTANT_MACROS -D__STDC_FORMAT_MACROS -D__STDC_LIMIT_MACROS -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\src -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\include -IC:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg\modules\core -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudev\include -IC:\Development\AE.AI\build\vcpkg_installed\x64-windows\include -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.8\include" -external:IC:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg -external:W0 /nologo /DWIN32 /D_WINDOWS /utf-8 /GR /MP   /D _CRT_SECURE_NO_DEPRECATE /D _CRT_NONSTDC_NO_DEPRECATE /D _SCL_SECURE_NO_WARNINGS /Gy /bigobj /Oi  /fp:precise /FS     /EHa /wd4127 /wd4251 /wd4324 /wd4275 /wd4512 /wd4589 /wd4819  /MDd /Z7 /Ob0 /Od /RTC1   -std:c++17 -MDd /showIncludes /Fomodules\core\CMakeFiles\opencv_core.dir\src\convert_c.cpp.obj /Fdlib\opencv_core4d.pdb /FS -c C:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\src\convert_c.cpp
[10/1352] C:\PROGRA~1\MICROS~1\2022\PROFES~1\VC\Tools\MSVC\1442~1.344\bin\Hostx64\x64\cl.exe   /TP -DCVAPI_EXPORTS -DOPENCV_ALLOCATOR_STATS_COUNTER_TYPE="long long" -D_USE_MATH_DEFINES -D_VARIADIC_MAX=10 -D_WIN32_WINNT=0x0601 -D__OPENCV_BUILD=1 -D__STDC_CONSTANT_MACROS -D__STDC_FORMAT_MACROS -D__STDC_LIMIT_MACROS -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\src -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\include -IC:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg\modules\core -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudev\include -IC:\Development\AE.AI\build\vcpkg_installed\x64-windows\include -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.8\include" -external:IC:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg -external:W0 /nologo /DWIN32 /D_WINDOWS /utf-8 /GR /MP   /D _CRT_SECURE_NO_DEPRECATE /D _CRT_NONSTDC_NO_DEPRECATE /D _SCL_SECURE_NO_WARNINGS /Gy /bigobj /Oi  /fp:precise /FS     /EHa /wd4127 /wd4251 /wd4324 /wd4275 /wd4512 /wd4589 /wd4819  /MDd /Z7 /Ob0 /Od /RTC1   -std:c++17 -MDd /showIncludes /Fomodules\core\CMakeFiles\opencv_core.dir\src\copy.cpp.obj /Fdlib\opencv_core4d.pdb /FS -c C:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\src\copy.cpp
[11/1352] C:\PROGRA~1\MICROS~1\2022\PROFES~1\VC\Tools\MSVC\1442~1.344\bin\Hostx64\x64\cl.exe   /TP -DCVAPI_EXPORTS -DOPENCV_ALLOCATOR_STATS_COUNTER_TYPE="long long" -D_USE_MATH_DEFINES -D_VARIADIC_MAX=10 -D_WIN32_WINNT=0x0601 -D__OPENCV_BUILD=1 -D__STDC_CONSTANT_MACROS -D__STDC_FORMAT_MACROS -D__STDC_LIMIT_MACROS -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\src -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\include -IC:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg\modules\core -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudev\include -IC:\Development\AE.AI\build\vcpkg_installed\x64-windows\include -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.8\include" -external:IC:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg -external:W0 /nologo /DWIN32 /D_WINDOWS /utf-8 /GR /MP   /D _CRT_SECURE_NO_DEPRECATE /D _CRT_NONSTDC_NO_DEPRECATE /D _SCL_SECURE_NO_WARNINGS /Gy /bigobj /Oi  /fp:precise /FS     /EHa /wd4127 /wd4251 /wd4324 /wd4275 /wd4512 /wd4589 /wd4819  /MDd /Z7 /Ob0 /Od /RTC1   -std:c++17 -MDd /showIncludes /Fomodules\core\CMakeFiles\opencv_core.dir\src\convert.dispatch.cpp.obj /Fdlib\opencv_core4d.pdb /FS -c C:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\src\convert.dispatch.cpp
[12/1352] C:\PROGRA~1\MICROS~1\2022\PROFES~1\VC\Tools\MSVC\1442~1.344\bin\Hostx64\x64\cl.exe   /TP -DCVAPI_EXPORTS -DOPENCV_ALLOCATOR_STATS_COUNTER_TYPE="long long" -D_USE_MATH_DEFINES -D_VARIADIC_MAX=10 -D_WIN32_WINNT=0x0601 -D__OPENCV_BUILD=1 -D__STDC_CONSTANT_MACROS -D__STDC_FORMAT_MACROS -D__STDC_LIMIT_MACROS -DHAVE_MALLOC_H=1 -DHAVE_WIN32_ALIGNED_MALLOC=1 -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\src -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\include -IC:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg\modules\core -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudev\include -IC:\Development\AE.AI\build\vcpkg_installed\x64-windows\include -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.8\include" -external:IC:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg -external:W0 /nologo /DWIN32 /D_WINDOWS /utf-8 /GR /MP   /D _CRT_SECURE_NO_DEPRECATE /D _CRT_NONSTDC_NO_DEPRECATE /D _SCL_SECURE_NO_WARNINGS /Gy /bigobj /Oi  /fp:precise /FS     /EHa /wd4127 /wd4251 /wd4324 /wd4275 /wd4512 /wd4589 /wd4819  /MDd /Z7 /Ob0 /Od /RTC1   -std:c++17 -MDd /showIncludes /Fomodules\core\CMakeFiles\opencv_core.dir\src\alloc.cpp.obj /Fdlib\opencv_core4d.pdb /FS -c C:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\src\alloc.cpp
[13/1352] C:\PROGRA~1\MICROS~1\2022\PROFES~1\VC\Tools\MSVC\1442~1.344\bin\Hostx64\x64\cl.exe   /TP -DCVAPI_EXPORTS -DOPENCV_ALLOCATOR_STATS_COUNTER_TYPE="long long" -D_USE_MATH_DEFINES -D_VARIADIC_MAX=10 -D_WIN32_WINNT=0x0601 -D__OPENCV_BUILD=1 -D__STDC_CONSTANT_MACROS -D__STDC_FORMAT_MACROS -D__STDC_LIMIT_MACROS -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\src -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\include -IC:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg\modules\core -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudev\include -IC:\Development\AE.AI\build\vcpkg_installed\x64-windows\include -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.8\include" -external:IC:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg -external:W0 /nologo /DWIN32 /D_WINDOWS /utf-8 /GR /MP   /D _CRT_SECURE_NO_DEPRECATE /D _CRT_NONSTDC_NO_DEPRECATE /D _SCL_SECURE_NO_WARNINGS /Gy /bigobj /Oi  /fp:precise /FS     /EHa /wd4127 /wd4251 /wd4324 /wd4275 /wd4512 /wd4589 /wd4819  /MDd /Z7 /Ob0 /Od /RTC1   -std:c++17 -MDd /showIncludes /Fomodules\core\CMakeFiles\opencv_core.dir\src\cuda_info.cpp.obj /Fdlib\opencv_core4d.pdb /FS -c C:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\src\cuda_info.cpp
[14/1352] C:\PROGRA~1\MICROS~1\2022\PROFES~1\VC\Tools\MSVC\1442~1.344\bin\Hostx64\x64\cl.exe   /TP -DCVAPI_EXPORTS -DOPENCV_ALLOCATOR_STATS_COUNTER_TYPE="long long" -D_USE_MATH_DEFINES -D_VARIADIC_MAX=10 -D_WIN32_WINNT=0x0601 -D__OPENCV_BUILD=1 -D__STDC_CONSTANT_MACROS -D__STDC_FORMAT_MACROS -D__STDC_LIMIT_MACROS -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\src -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\include -IC:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg\modules\core -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudev\include -IC:\Development\AE.AI\build\vcpkg_installed\x64-windows\include -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.8\include" -external:IC:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg -external:W0 /nologo /DWIN32 /D_WINDOWS /utf-8 /GR /MP   /D _CRT_SECURE_NO_DEPRECATE /D _CRT_NONSTDC_NO_DEPRECATE /D _SCL_SECURE_NO_WARNINGS /Gy /bigobj /Oi  /fp:precise /FS     /EHa /wd4127 /wd4251 /wd4324 /wd4275 /wd4512 /wd4589 /wd4819  /MDd /Z7 /Ob0 /Od /RTC1   -std:c++17 -MDd /showIncludes /Fomodules\core\CMakeFiles\opencv_core.dir\src\algorithm.cpp.obj /Fdlib\opencv_core4d.pdb /FS -c C:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\src\algorithm.cpp
[15/1352] C:\PROGRA~1\MICROS~1\2022\PROFES~1\VC\Tools\MSVC\1442~1.344\bin\Hostx64\x64\cl.exe   /TP -DCVAPI_EXPORTS -DOPENCV_ALLOCATOR_STATS_COUNTER_TYPE="long long" -D_USE_MATH_DEFINES -D_VARIADIC_MAX=10 -D_WIN32_WINNT=0x0601 -D__OPENCV_BUILD=1 -D__STDC_CONSTANT_MACROS -D__STDC_FORMAT_MACROS -D__STDC_LIMIT_MACROS -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\src -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\include -IC:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg\modules\core -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudev\include -IC:\Development\AE.AI\build\vcpkg_installed\x64-windows\include -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.8\include" -external:IC:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg -external:W0 /nologo /DWIN32 /D_WINDOWS /utf-8 /GR /MP   /D _CRT_SECURE_NO_DEPRECATE /D _CRT_NONSTDC_NO_DEPRECATE /D _SCL_SECURE_NO_WARNINGS /Gy /bigobj /Oi  /fp:precise /FS     /EHa /wd4127 /wd4251 /wd4324 /wd4275 /wd4512 /wd4589 /wd4819  /MDd /Z7 /Ob0 /Od /RTC1   -std:c++17 -MDd /showIncludes /Fomodules\core\CMakeFiles\opencv_core.dir\src\async.cpp.obj /Fdlib\opencv_core4d.pdb /FS -c C:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\src\async.cpp
Skipped 6540 lines
            instantiation of "InputIt thrust::THRUST_200700_500_520_600_610_700_750_800_860_890_900_NS::cuda_cub::remove_if(thrust::THRUST_200700_500_520_600_610_700_750_800_860_890_900_NS::cuda_cub::execution_policy<Derived> &, InputIt, InputIt, StencilIt, Predicate) [with Derived=thrust::THRUST_200700_500_520_600_610_700_750_800_860_890_900_NS::cuda_cub::tag, InputIt=thrust::THRUST_200700_500_520_600_610_700_750_800_860_890_900_NS::zip_iterator<thrust::THRUST_200700_500_520_600_610_700_750_800_860_890_900_NS::tuple<thrust::THRUST_200700_500_520_600_610_700_750_800_860_890_900_NS::device_ptr<float2>, thrust::THRUST_200700_500_520_600_610_700_750_800_860_890_900_NS::device_ptr<float2>>>, StencilIt=thrust::THRUST_200700_500_520_600_610_700_750_800_860_890_900_NS::device_ptr<const uchar>, Predicate=thrust::THRUST_200700_500_520_600_610_700_750_800_860_890_900_NS::unary_negate<thrust::THRUST_200700_500_520_600_610_700_750_800_860_890_900_NS::identity<uchar>>]" at line 96 of C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\include\thrust/detail/remove.inl
            instantiation of "ForwardIterator thrust::THRUST_200700_500_520_600_610_700_750_800_860_890_900_NS::remove_if(const thrust::THRUST_200700_500_520_600_610_700_750_800_860_890_900_NS::detail::execution_policy_base<DerivedPolicy> &, ForwardIterator, ForwardIterator, InputIterator, Predicate) [with DerivedPolicy=thrust::THRUST_200700_500_520_600_610_700_750_800_860_890_900_NS::cuda_cub::tag, ForwardIterator=thrust::THRUST_200700_500_520_600_610_700_750_800_860_890_900_NS::zip_iterator<thrust::THRUST_200700_500_520_600_610_700_750_800_860_890_900_NS::tuple<thrust::THRUST_200700_500_520_600_610_700_750_800_860_890_900_NS::device_ptr<float2>, thrust::THRUST_200700_500_520_600_610_700_750_800_860_890_900_NS::device_ptr<float2>>>, InputIterator=thrust::THRUST_200700_500_520_600_610_700_750_800_860_890_900_NS::device_ptr<const uchar>, Predicate=thrust::THRUST_200700_500_520_600_610_700_750_800_860_890_900_NS::unary_negate<thrust::THRUST_200700_500_520_600_610_700_750_800_860_890_900_NS::identity<uchar>>]" at line 167 of C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\include\thrust/detail/remove.inl
            instantiation of "ForwardIterator thrust::THRUST_200700_500_520_600_610_700_750_800_860_890_900_NS::remove_if(ForwardIterator, ForwardIterator, InputIterator, Predicate) [with ForwardIterator=thrust::THRUST_200700_500_520_600_610_700_750_800_860_890_900_NS::zip_iterator<thrust::THRUST_200700_500_520_600_610_700_750_800_860_890_900_NS::tuple<thrust::THRUST_200700_500_520_600_610_700_750_800_860_890_900_NS::device_ptr<float2>, thrust::THRUST_200700_500_520_600_610_700_750_800_860_890_900_NS::device_ptr<float2>>>, InputIterator=thrust::THRUST_200700_500_520_600_610_700_750_800_860_890_900_NS::device_ptr<const uchar>, Predicate=thrust::THRUST_200700_500_520_600_610_700_750_800_860_890_900_NS::unary_negate<thrust::THRUST_200700_500_520_600_610_700_750_800_860_890_900_NS::identity<uchar>>]" at line 61 of C:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\videostab\src\cuda\global_motion.cu
Remark: The warnings can be suppressed with "-diag-suppress <warning-number>"
nvcc warning : Support for offline compilation for architectures prior to '<compute/sm/lto>_75' will be removed in a future release (Use -Wno-deprecated-gpu-targets to suppress warning).
global_motion.cu
cl : Command line warning D9025 : overriding '/Zi' with '/Z7'
tmpxft_000051dc_00000000-7_global_motion.compute_90.cudafe1.cpp
C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\include\thrust/detail/config/cpp_dialect.h:117: warning: Thrust requires at least C++ 17.C++ 14 is deprecated but still supported.C++ 14 support will be removed in a future release.Define THRUST_IGNORE_DEPRECATED_CPP_DIALECT to suppress this message.
C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\include\cub/util_cpp_dialect.cuh:129: warning: CUB requires at least C++ 17.C++ 14 is deprecated but still supported.C++ 14 support will be removed in a future release.Define CUB_IGNORE_DEPRECATED_CPP_DIALECT to suppress this message.
[1310/1352] C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\bin\nvcc.exe -forward-unknown-to-host-compiler -DCVAPI_EXPORTS -D_USE_MATH_DEFINES -D_VARIADIC_MAX=10 -D_WIN32_WINNT=0x0601 -D__OPENCV_BUILD=1 -D__STDC_CONSTANT_MACROS -D__STDC_FORMAT_MACROS -D__STDC_LIMIT_MACROS -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudastereo\src -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudastereo\include -IC:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg\modules\cudastereo -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudev\include -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\include -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\flann\include -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\imgproc\include -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\features2d\include -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\calib3d\include -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.8\include" -isystem C:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg -D_WINDOWS -Xcompiler=" /GR /EHsc" -Xcompiler=" -Zi -Ob0 -Od /RTC1" -std=c++14 "--generate-code=arch=compute_50,code=[sm_50]" "--generate-code=arch=compute_52,code=[sm_52]" "--generate-code=arch=compute_60,code=[sm_60]" "--generate-code=arch=compute_61,code=[sm_61]" "--generate-code=arch=compute_70,code=[sm_70]" "--generate-code=arch=compute_75,code=[sm_75]" "--generate-code=arch=compute_80,code=[sm_80]" "--generate-code=arch=compute_86,code=[sm_86]" "--generate-code=arch=compute_89,code=[sm_89]" "--generate-code=arch=compute_90,code=[sm_90]" "--generate-code=arch=compute_90,code=[compute_90]" -Xcompiler=-MDd -D_FORCE_INLINES -Xcompiler=-DCVAPI_EXPORTS -Xcudafe --display_error_number --diag-suppress 1394,1388 "-Xcompiler=  /nologo /DWIN32 /D_WINDOWS /utf-8 /GR /MP   /D _CRT_SECURE_NO_DEPRECATE /D _CRT_NONSTDC_NO_DEPRECATE /D _SCL_SECURE_NO_WARNINGS /Gy /bigobj /Oi  /fp:precise /FS      /wd4127 /wd4251 /wd4324 /wd4275 /wd4512 /wd4589 /wd4819 /wd4127 /wd4324 /wd4512  /MDd /Z7 /Ob0 /Od /RTC1     " -MD -MT modules\cudastereo\CMakeFiles\opencv_cudastereo.dir\src\cuda\stereobm.cu.obj -MF modules\cudastereo\CMakeFiles\opencv_cudastereo.dir\src\cuda\stereobm.cu.obj.d -x cu -c C:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudastereo\src\cuda\stereobm.cu -o modules\cudastereo\CMakeFiles\opencv_cudastereo.dir\src\cuda\stereobm.cu.obj -Xcompiler=-Fdlib\opencv_cudastereo4d.pdb,-FS
FAILED: modules/cudastereo/CMakeFiles/opencv_cudastereo.dir/src/cuda/stereobm.cu.obj
stereobm.cu
stereobm.cu
stereobm.cu
stereobm.cu
stereobm.cu
stereobm.cu
stereobm.cu
stereobm.cu
stereobm.cu
stereobm.cu
stereobm.cu
stereobm.cu
[1311/1352] C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\bin\nvcc.exe -forward-unknown-to-host-compiler -DCVAPI_EXPORTS -D_USE_MATH_DEFINES -D_VARIADIC_MAX=10 -D_WIN32_WINNT=0x0601 -D__OPENCV_BUILD=1 -D__STDC_CONSTANT_MACROS -D__STDC_FORMAT_MACROS -D__STDC_LIMIT_MACROS -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudawarping\src -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudawarping\include -IC:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg\modules\cudawarping -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudev\include -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\include -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\imgproc\include -isystem C:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg -isystem "C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.8\include" -D_WINDOWS -Xcompiler=" /GR /EHsc" -Xcompiler=" -Zi -Ob0 -Od /RTC1" -std=c++14 "--generate-code=arch=compute_50,code=[sm_50]" "--generate-code=arch=compute_52,code=[sm_52]" "--generate-code=arch=compute_60,code=[sm_60]" "--generate-code=arch=compute_61,code=[sm_61]" "--generate-code=arch=compute_70,code=[sm_70]" "--generate-code=arch=compute_75,code=[sm_75]" "--generate-code=arch=compute_80,code=[sm_80]" "--generate-code=arch=compute_86,code=[sm_86]" "--generate-code=arch=compute_89,code=[sm_89]" "--generate-code=arch=compute_90,code=[sm_90]" "--generate-code=arch=compute_90,code=[compute_90]" -Xcompiler=-MDd -D_FORCE_INLINES -Xcompiler=-DCVAPI_EXPORTS -Xcudafe --display_error_number --diag-suppress 1394,1388 "-Xcompiler=  /nologo /DWIN32 /D_WINDOWS /utf-8 /GR /MP   /D _CRT_SECURE_NO_DEPRECATE /D _CRT_NONSTDC_NO_DEPRECATE /D _SCL_SECURE_NO_WARNINGS /Gy /bigobj /Oi  /fp:precise /FS      /wd4127 /wd4251 /wd4324 /wd4275 /wd4512 /wd4589 /wd4819 /wd4127 /wd4324 /wd4512  /MDd /Z7 /Ob0 /Od /RTC1     " -MD -MT modules\cudawarping\CMakeFiles\opencv_cudawarping.dir\src\cuda\warp.cu.obj -MF modules\cudawarping\CMakeFiles\opencv_cudawarping.dir\src\cuda\warp.cu.obj.d -x cu -c C:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudawarping\src\cuda\warp.cu -o modules\cudawarping\CMakeFiles\opencv_cudawarping.dir\src\cuda\warp.cu.obj -Xcompiler=-Fdlib\opencv_cudawarping4d.pdb,-FS
FAILED: modules/cudawarping/CMakeFiles/opencv_cudawarping.dir/src/cuda/warp.cu.obj
warp.cu
warp.cu
warp.cu
warp.cu
warp.cu
warp.cu
warp.cu
warp.cu
warp.cu
warp.cu
warp.cu
Wrote crash dump file "C:\Users\RyanS\AppData\Local\Temp\cicc.exe-14cd1e.dmp"
llvm-symbolizer.exe: error: 'C:\WINDOWS\System32\KERNEL32.DLL': 'kernel32.pdb': no such file or directory
llvm-symbolizer.exe: error: 'C:\WINDOWS\SYSTEM32\ntdll.dll': 'ntdll.pdb': no such file or directory
#0 0x00007ff7105787c0 (C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\nvvm\bin\cicc.exe+0x21687c0)
#1 0x00007ff710579dea (C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\nvvm\bin\cicc.exe+0x2169dea)
#2 0x00007ff710579ee3 (C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\nvvm\bin\cicc.exe+0x2169ee3)
#3 0x00007ff71057a275 (C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\nvvm\bin\cicc.exe+0x216a275)
#4 0x00007ff7105792d5 (C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\nvvm\bin\cicc.exe+0x21692d5)
#5 0x00007ff7103b893e (C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\nvvm\bin\cicc.exe+0x1fa893e)
#6 0x00007ff7103b77c5 (C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\nvvm\bin\cicc.exe+0x1fa77c5)
#7 0x00007ff7103a3c3d (C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\nvvm\bin\cicc.exe+0x1f93c3d)
#8 0x00007ff71039ceca (C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\nvvm\bin\cicc.exe+0x1f8ceca)
#9 0x00007ff71034e675 (C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\nvvm\bin\cicc.exe+0x1f3e675)
#10 0x00007ff71034bfdf (C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\nvvm\bin\cicc.exe+0x1f3bfdf)
#11 0x00007ff71034f815 (C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\nvvm\bin\cicc.exe+0x1f3f815)
#12 0x00007ff70e947a95 (C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\nvvm\bin\cicc.exe+0x537a95)
#13 0x00007ff70e94d89c (C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\nvvm\bin\cicc.exe+0x53d89c)
#14 0x00007ffde8aae8d7 (C:\WINDOWS\System32\KERNEL32.DLL+0x2e8d7)
#15 0x00007ffdea2d14fc (C:\WINDOWS\SYSTEM32\ntdll.dll+0xb14fc)
warp.cu
[1312/1352] C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\bin\nvcc.exe -forward-unknown-to-host-compiler -DCVAPI_EXPORTS -DHAVE_NVIDIA_OPTFLOW=2 -D_USE_MATH_DEFINES -D_VARIADIC_MAX=10 -D_WIN32_WINNT=0x0601 -D__OPENCV_BUILD=1 -D__STDC_CONSTANT_MACROS -D__STDC_FORMAT_MACROS -D__STDC_LIMIT_MACROS -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudaoptflow\src -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudaoptflow\include -IC:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg\modules\cudaoptflow -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudev\include -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\include -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudaarithm\include -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\flann\include -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\imgproc\include -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudafilters\include -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudaimgproc\include -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudawarping\include -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\dnn\include -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\features2d\include -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\imgcodecs\include -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\calib3d\include -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\objdetect\include -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\video\include -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\ximgproc\include -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudalegacy\include -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\optflow\include -isystem C:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg\3rdparty\NVIDIAOpticalFlowSDK_2_0_Headers\NVIDIAOpticalFlowSDK-edb50da3cf849840d680249aa6dbef248ebce2ca -isystem C:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg -isystem "C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.8\include" -D_WINDOWS -Xcompiler=" /GR /EHsc" -Xcompiler=" -Zi -Ob0 -Od /RTC1" -std=c++14 "--generate-code=arch=compute_50,code=[sm_50]" "--generate-code=arch=compute_52,code=[sm_52]" "--generate-code=arch=compute_60,code=[sm_60]" "--generate-code=arch=compute_61,code=[sm_61]" "--generate-code=arch=compute_70,code=[sm_70]" "--generate-code=arch=compute_75,code=[sm_75]" "--generate-code=arch=compute_80,code=[sm_80]" "--generate-code=arch=compute_86,code=[sm_86]" "--generate-code=arch=compute_89,code=[sm_89]" "--generate-code=arch=compute_90,code=[sm_90]" "--generate-code=arch=compute_90,code=[compute_90]" -Xcompiler=-MDd -D_FORCE_INLINES -Xcompiler=-DCVAPI_EXPORTS -Xcudafe --display_error_number --diag-suppress 1394,1388 "-Xcompiler=  /nologo /DWIN32 /D_WINDOWS /utf-8 /GR /MP   /D _CRT_SECURE_NO_DEPRECATE /D _CRT_NONSTDC_NO_DEPRECATE /D _SCL_SECURE_NO_WARNINGS /Gy /bigobj /Oi  /fp:precise /FS      /wd4127 /wd4251 /wd4324 /wd4275 /wd4512 /wd4589 /wd4819 /wd4127 /wd4324 /wd4512  /MDd /Z7 /Ob0 /Od /RTC1     " -MD -MT modules\cudaoptflow\CMakeFiles\opencv_cudaoptflow.dir\src\cuda\pyrlk.cu.obj -MF modules\cudaoptflow\CMakeFiles\opencv_cudaoptflow.dir\src\cuda\pyrlk.cu.obj.d -x cu -c C:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudaoptflow\src\cuda\pyrlk.cu -o modules\cudaoptflow\CMakeFiles\opencv_cudaoptflow.dir\src\cuda\pyrlk.cu.obj -Xcompiler=-Fdlib\opencv_cudaoptflow4d.pdb,-FS
FAILED: modules/cudaoptflow/CMakeFiles/opencv_cudaoptflow.dir/src/cuda/pyrlk.cu.obj
pyrlk.cu
pyrlk.cu
pyrlk.cu
pyrlk.cu
pyrlk.cu
pyrlk.cu
pyrlk.cu
pyrlk.cu
pyrlk.cu
pyrlk.cu
pyrlk.cu
Wrote crash dump file "C:\Users\RyanS\AppData\Local\Temp\cicc.exe-cdf418.dmp"
#0 0x00007ff710aeb7c7 (C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\nvvm\bin\cicc.exe+0x26db7c7)
#1 0x00007ff710fa7ec9 (C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\nvvm\bin\cicc.exe+0x2b97ec9)
#2 0x00007ff710fa9b96 (C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\nvvm\bin\cicc.exe+0x2b99b96)
#3 0x00007ff710ceb282 (C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\nvvm\bin\cicc.exe+0x28db282)
#4 0x00007ff710579c55 (C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\nvvm\bin\cicc.exe+0x2169c55)
#5 0x00007ff710579ee3 (C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\nvvm\bin\cicc.exe+0x2169ee3)
#6 0x00007ff71057a275 (C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\nvvm\bin\cicc.exe+0x216a275)
#7 0x00007ff7105792d5 (C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\nvvm\bin\cicc.exe+0x21692d5)
#8 0x00007ff7103b893e (C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\nvvm\bin\cicc.exe+0x1fa893e)
#9 0x00007ff7103b77c5 (C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\nvvm\bin\cicc.exe+0x1fa77c5)
#10 0x00007ff7103a3c3d (C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\nvvm\bin\cicc.exe+0x1f93c3d)
#11 0x00007ff71039ceca (C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\nvvm\bin\cicc.exe+0x1f8ceca)
#12 0x00007ff71034e675 (C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\nvvm\bin\cicc.exe+0x1f3e675)
#13 0x00007ff71034bfdf (C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\nvvm\bin\cicc.exe+0x1f3bfdf)
#14 0x00007ff71034f815 (C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\nvvm\bin\cicc.exe+0x1f3f815)
#15 0x00007ff70e947a95 (C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\nvvm\bin\cicc.exe+0x537a95)
#16 0x00007ff70e94d89c (C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\nvvm\bin\cicc.exe+0x53d89c)
#17 0x00007ffde8aae8d7 (C:\WINDOWS\System32\KERNEL32.DLL+0x2e8d7)
#18 0x00007ffdea2d14fc (C:\WINDOWS\SYSTEM32\ntdll.dll+0xb14fc)
pyrlk.cu
[1313/1352] C:\PROGRA~1\NVIDIA~2\CUDA\v12.8\bin\nvcc.exe -forward-unknown-to-host-compiler -DCVAPI_EXPORTS -D_USE_MATH_DEFINES -D_VARIADIC_MAX=10 -D_WIN32_WINNT=0x0601 -D__OPENCV_BUILD=1 -D__STDC_CONSTANT_MACROS -D__STDC_FORMAT_MACROS -D__STDC_LIMIT_MACROS -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudafeatures2d\src -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudafeatures2d\include -IC:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg\modules\cudafeatures2d -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudev\include -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\core\include -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudaarithm\include -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\flann\include -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\imgproc\include -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudafilters\include -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudawarping\include -IC:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-db32e53cd3.clean\modules\features2d\include -isystem C:\Development\vcpkg\buildtrees\opencv4\x64-windows-dbg -isystem "C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.8\include" -D_WINDOWS -Xcompiler=" /GR /EHsc" -Xcompiler=" -Zi -Ob0 -Od /RTC1" -std=c++14 "--generate-code=arch=compute_50,code=[sm_50]" "--generate-code=arch=compute_52,code=[sm_52]" "--generate-code=arch=compute_60,code=[sm_60]" "--generate-code=arch=compute_61,code=[sm_61]" "--generate-code=arch=compute_70,code=[sm_70]" "--generate-code=arch=compute_75,code=[sm_75]" "--generate-code=arch=compute_80,code=[sm_80]" "--generate-code=arch=compute_86,code=[sm_86]" "--generate-code=arch=compute_89,code=[sm_89]" "--generate-code=arch=compute_90,code=[sm_90]" "--generate-code=arch=compute_90,code=[compute_90]" -Xcompiler=-MDd -D_FORCE_INLINES -Xcompiler=-DCVAPI_EXPORTS -Xcudafe --display_error_number --diag-suppress 1394,1388 "-Xcompiler=  /nologo /DWIN32 /D_WINDOWS /utf-8 /GR /MP   /D _CRT_SECURE_NO_DEPRECATE /D _CRT_NONSTDC_NO_DEPRECATE /D _SCL_SECURE_NO_WARNINGS /Gy /bigobj /Oi  /fp:precise /FS      /wd4127 /wd4251 /wd4324 /wd4275 /wd4512 /wd4589 /wd4819 /wd4127 /wd4100 /wd4324 /wd4512 /wd4515  /MDd /Z7 /Ob0 /Od /RTC1     " -MD -MT modules\cudafeatures2d\CMakeFiles\opencv_cudafeatures2d.dir\src\cuda\orb.cu.obj -MF modules\cudafeatures2d\CMakeFiles\opencv_cudafeatures2d.dir\src\cuda\orb.cu.obj.d -x cu -c C:\Development\vcpkg\buildtrees\opencv4\src\4.10.0-64012148a7.clean\modules\cudafeatures2d\src\cuda\orb.cu -o modules\cudafeatures2d\CMakeFiles\opencv_cudafeatures2d.dir\src\cuda\orb.cu.obj -Xcompiler=-Fdlib\opencv_cudafeatures2d4d.pdb,-FS
orb.cu
orb.cu
orb.cu
orb.cu
orb.cu
orb.cu
orb.cu
orb.cu
orb.cu
orb.cu
orb.cu
orb.cu
tmpxft_00005b28_00000000-7_orb.compute_90.cudafe1.cpp
ninja: build stopped: subcommand failed.
Additional context
vcpkg.json
  "dependencies": [
      "name": "opencv4",
      "version>=": "4.10.0",
      "features": [
        "cuda",
        "thread"
      "name": "protobuf",
      "version>=": "5.29.2"
      "name": "nlohmann-json",
      "version>=": "3.11.3"
      "name": "grpc",
      "version>=": "1.68.0"
      "name": "gtest",
      "version>=": "1.15.2"
      "name": "tiff",
      "version>=": "4.7.0"
      "name": "openssl",
      "version>=": "3.4.0"
      "name": "zlib",
      "version>=": "1.3.1"
      "name": "wxwidgets",
      "version>=": "3.2.6"
  "builtin-baseline": "6f29f12e82a8293156836ad81cc9bf5af41fe836"
Also, I found a few other threads that say it could be related to path and other versions installed.
where.exe cl.exe
C:\Program Files\Microsoft Visual Studio\2022\Professional\VC\Tools\MSVC\14.42.34433\bin\Hostx64\x64\cl.exe
 where.exe nvcc.exe
C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.8\bin\nvcc.exe
bump?
