CMU_CLOCKS RAS Uncorrectable Error, ADC0 VMON Error, and Powering off core
Hello NVIDIA team,
I am experiencing a persistent boot failure on one Jetson AGX Orin module.
I installed the module on a new NVIDIA official Jetson AGX Orin developer kit carrier board and used a fresh JetPack 7.2 / Jetson Linux r39.2 BSP package.
I flash the orin with: sudo ./flash.sh jetson-agx-orin-devkit internal
After the flashing process completed successfully, the system froze for a while and then rebooted while I was configuring the time zone and user information. After connecting to the serial console, I found the following messages:
ERROR: **************************************
ERROR: RAS Uncorrectable Error in CMU_CLOCKS, base=0xe003000:
ERROR: Status = 0x64000101
ERROR: SERR = IMPLEMENTATION DEFINED error: 0x1
ERROR: IERR = ADC0 VMON Error: 0x1
ERROR: MISC0 = 0x124580000
ERROR: MISC1 = 0x0
ERROR: MISC2 = 0x0
ERROR: MISC3 = 0x0
ERROR: sdei_dispatch_event returned -1
ERROR: Powering off core
Please let me know if you need any additional information. Could you please advise what steps I should take to resolve this issue and whether the module needs to be processed for RMA?
Thank you
Will you hit same issue if falling back to use jp6?
thanks for reply
Today I also tried flashing JetPack 6.2.2, but the installation failed with both SDK Manager and sudo ./flash.sh jetson-agx-orin-devkit internal
The flashing process remained stuck at “applet/mb2 is not running on this device” for a very long time and did not make any further progress until I manually cancelled the installation.
What is the UART side log?
same error
▒▒ERROR: **************************************
ERROR: MISC0 = 0x2fbfc0000
ERROR: MISC1 = 0x0
ERROR: MISC2 = 0x0
ERROR: MISC3 = 0x0
jetson-6.2.2-flash-uart.txt (114.2 KB)
jetson-6.2.2-flash.log (84.8 KB)
Please do the RMA for this SOM.
