4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
Model:
Driver Version:
Topic Description
Detailed Description
If I create a Xform and a Mesh and apply Rigid Body with colliders preset from the GUI, it behaves correctly, but I want to be able to turn this on and off via code.
Steps to Reproduce
Create Xform
Create Child Cube Mesh
Run the scripts
# Apply all physics APIs
UsdPhysics.RigidBodyAPI.Apply(prim)
PhysxSchema.PhysxRigidBodyAPI.Apply(prim)
UsdPhysics.CollisionAPI.Apply(prim)
PhysxSchema.PhysxCollisionAPI.Apply(prim)
Demo
The one in the left I used the GUI:
Add > Physics > Rigid body with colliders preset
The on in the right:
Why they behave differently? How to achieve the same behavior from code?
Do you set schemas attributes (like RigidBodyEnabled one) after applying them? If you only apply them, it doesn’t has any effect except prepending schemas in apiSchemas prim list:
You can check it by yourself. Create stage with two cubes. Add ‘Rigid Body with colliders preset’ to one of them with GUI and perform your code on another. Then save your file as .usda and see the difference between them.
