Trying to create a Windows screen capture app that uses DXGI to grab the screen and Codec SDK V9.0 to encode as H264. Problem I am seeing is that if I even link CUDA LIB into my app without even making any calls then DXGI setup fails. Specifically I get error 0x887a0004 from
Sorry - Version 8.2.15 of the codec SDK.
My adaptor is a Quadro K1100M
My CUDA libraries are 9.0
Window 10
VS2015
Driver version shows 23.21.13.9174 dated 6/4/18
I have a ZIP file containing source and project file for a standalone sample app that shows the problem but its not clear how I can upload that on this forum. (Sorry - I’m new here).
mcervny, thanks for the suggestion but that particular topic did not seem directly related to my problem. I do have a machine with 2 adaptors (intel and NVIDIA Quadro) but my DXGI code normally has no problems talking to either one of those adaptors. However if I link to CUDA.LIB even without making any calls then both adaptors fail with DXGI. Something is presumably happening in DllMain() in one of the CUDA dlls to cause this. Hopefully Ryan can sort it out.
The short of it is: “This issue occurs because the DDA does not support being run against the discrete GPU on a Microsoft Hybrid system. By design, the call fails together with error code DXGI_ERROR_UNSUPPORTED in such a scenario.”
