colcon build of ros2_workspace results in stderr: isaac_ros_navigation_goal
Finished <<< isaac_ros2_messages [0.38s]
— stderr: isaac_ros_navigation_goal
/home/meta/.local/lib/python3.8/site-packages/setuptools/dist.py:717: UserWarning: Usage of dash-separated ‘script-dir’ will not be supported in future versions. Please use the underscore name ‘script_dir’ instead
warnings.warn(
/home/meta/.local/lib/python3.8/site-packages/setuptools/dist.py:717: UserWarning: Usage of dash-separated ‘install-scripts’ will not be supported in future versions. Please use the underscore name ‘install_scripts’ instead
warnings.warn(
Finished <<< isaac_ros_navigation_goal [0.72s]
Summary: 6 packages finished [0.89s]
1 package had stderr output: isaac_ros_navigation_goal
