jcagle
July 13, 2026, 10:19pm
1
A colleague just mentioned this, itβs on macOS, but the same concept could be used on DGX Spark:
Run GLM-5.2 (744B MoE) on a 25GB-RAM consumer machine β pure C, zero deps, experts streamed from disk. Tiny engine, immense model. π¦
Has anyone tried this yet?
Like only works in an offline analysis capacity, check the Tk/s projections
An interesting start apparentlyβ¦ Hopefully @Vincent might give us a report at some point. π
opened 01:37AM - 14 Jul 26 UTC
Machine:** NVIDIA DGX Spark (`NVIDIA_DGX_Spark`) Β· Ubuntu 24.04 Β· Linux 6.17.0-1β¦ 008-nvidia aarch64
**CPU:** 10Γ Cortex-X925 @ 3.9 GHz + 10Γ Cortex-A725 @ 2.8 GHz (20 cores)
**Memory:** 121 GB unified (CPU/GPU shared)
**GPU:** NVIDIA GB10 (sm_121), driver 580.126.09
**Disk:** NVMe (`/dev/nvme0n1p2`), model on local ext4
**Model:** GLM-5.2 colibri int4 Β· **int8 MTP heads** (sizes match matey-0 clone: 3527131672 / 5366238584 / 1065950496)
**Engine base:** `JustVugg/colibri` @ `a78a06f` + local experimental patches (CACHE_ROUTE / TRACE_EXPERTS / CUDA unified path)
## Disk (README protocol)
`c/iobench` Β· 19 MB Γ 64 reads Β· 8 threads Β· shard `out-00099.safetensors`:
| mode | measured |
| buffered | **4.25 GB/s** |
| **O_DIRECT** | **9.69 GB/s** |
## How to read these numbers
Community table rows are usually **stock routing (full top-8)** with **decode tok/s** from the coli stats line after warm-up. This report has **two tiers**:
1. **Tier A β full top-8, no routing change** (config `num_experts_per_tok=8`)
2. **Tier B β experimental `CACHE_ROUTE`** (opt-in, not upstream default; ~14% expert substitution vs true top-8; cache-aware routing, arXiv:2412.00099 max-rank)
Also:
- **Decode tok/s** = generation window only (coli `decode tok/s`). **Overall** includes prefill β do not use overall for ranking.
- **`MTP=0` / `DRAFT=0`** for these speed cells.
- Chat used **`TEMP=0.7`**. Output on the primes prompt was the correct first-20 list every turn.
- Short context via **`:reset` each turn** (clears KV only; pin/LRU survive).
## Tier A β full top-8, stock routing (`TOPK` unset, no CACHE_ROUTE)
Config: `COLI_CUDA_UNIFIED=1` Β· `CUDA_DENSE=1` Β· `CUDA_GROUPED=1` Β· `DIRECT=1` Β· `PIPE=1` Β· large session LRU Β· learned AUTOPIN.
| cell | protocol | decode tok/s | hit | notes |
| Timed `./glm` PROFILE | WARM=160, NGEN=48, greedy `TEMP=0` | **2.39** | 82% | best non-interactive full
| Chat (warm session) | primes prompt, `:reset` each turn | **~2.08** | ~82% | chat ladder peak before CA
Example footer (preβCACHE_ROUTE):
```text
ββ 39 tok Β· 2.08 decode tok/s Β· β¦ Β· hit 82% Β· RSS ~76 GB
miss ~107/tok Β· I/O ~8.5s Β· expert ~3.2s Β· attention ~3.9s
βββ
Tier B β experimental CACHE_ROUTE (opt-in; not stock default)
CACHE_ROUTE=1 ROUTE_J=2 ROUTE_M=12
# keep true top-2; fill remaining 6 slots preferring pinβͺLRU experts ranked in top-12
Sandbox predicted hit 0.81β0.955 and ~14% substitution. Live chat matches substitution and exceeds the hit target.
Interactive chat ladder
Prompt each turn:
List the first 20 prime numbers, one per line.
Protocol: one long-lived session Β· :reset before every turn Β· same prompt Β· full top-8 K Β· CACHE_ROUTE on.
ββββββββ¬ββββββ¬βββββββββββββββ¬ββββββ¬βββββββ¬βββββββ¬βββββββββββ
β turn β tok β decode tok/s β hit β swap β I/O β miss/tok β
ββββββββΌββββββΌβββββββββββββββΌββββββΌβββββββΌβββββββΌβββββββββββ€
β 1 β 41 β 3.01 β 95% β 15% β 2.8s β 32.6 β
β 2 β 39 β 3.16 β 96% β 15% β 2.1s β 25.1 β
β 4 β 39 β 3.24 β 96% β 14% β 1.8s β 21.2 β
β 6 β 39 β 3.29 β 97% β 14% β 1.6s β 18.4 β
β best β 41 β 3.33 β 97% β 14% β 1.5s β 18.0 β
ββββββββ΄ββββββ΄βββββββββββββββ΄ββββββ΄βββββββ΄βββββββ΄βββββββββββ
Best (Tier B): 3.33 decode tok/s Β· hit 97% Β· swap 14% Β· RSS 78.5 GB Β· wall ~18s for 41 tokens.
Verbatim footer:
ββ 41 tok Β· 3.33 decode tok/s Β· 2.27 overall Β· hit 97% Β· swap 14% Β· RSS 78.5 GB Β· 18s
miss 18.0/tok (0.34 GB/tok) Β· MTP 1.00 tok/fw (0% accept) Β· I/O 1.5s Β· expert 3.2s Β· attention 4.1s
CUDA 112.5% of expert calls (27675 calls) Β· 1.00 rows/expert
cache admission 80 accepted Β· 660 scan-pollution rejects
Output quality on this prompt: correct first-20 primes every turn. Not a full ./coli bench quality gate β still pending before defaulting CACHE_ROUTE.
Timed one-shot (heavy warm, less favorable than multi-turn chat LRU):
48 tokens in 18.00s (2.67 tok/s decode) | expert hit rate 93.5% | swap 15.0%
PROFILE: expert-disk 3.852s | expert-matmul 3.833s | attention 6.155s | other 4.162s
Iβm very curious if this system could scale to two Sparks using an analogue of expert parallel. Twice the resident RAM, twice the SSD read bandwidth.
Sounds like a job for Fable :D
mashie
July 14, 2026, 3:40pm
6
Besides proving it can be done, what is the point of this?
Also what is the PP speed, only token generation is covered in those benchmarks?
You wouldnβt be using this for coding, but GLM 5.2 is considered the SOTA local writing/translation model. For those tasks you usually turn off reasoning, so 3 tok/sec is not so awful, itβs faster than most peopleβs typing speed. Youβd only choose this over a cloud model (even GLM 5.2 by API) for privacy though, itβs inconvenient.
mashie
July 27, 2026, 6:16pm
8
Most users on this forum with 4 sparks or more are running GLM 5.2 at 8+ times that speed, at which point it is useful.
At 3 tokens per second it really is a science project at best.
