This is Bongjae Moon.
Describe the bug In src/eval/src/eval/scorers/collision.py, CollisionScorer.calculate() resets front_collision, rear_collision and lateral_collision inside the loop over intersecting actors (L47), and appends them after the loop (L54–56). When two or more actors overlap the ego in the same timestep, only the classification of the last actor returned by srt_tree.query(...) survives.
The iteration order follows the spatial layout and ego heading, not the input order. The same physical contact can therefore be scored differently: flipping the ego heading drops a front contact, and because collision_at_fault = collision_front | collision_lateral (aggregation/processing.py), at-fault changes from True to False.
Steps/Code to reproduce bug Standalone snippet that mirrors the scorer’s loop (shapely only):
from shapely.geometry import box, LineString
front_bumper = LineString([(4, -1), (4, 1)]) # ego bbox (0,-1)-(4,1), heading +x
rear_bumper = LineString([(0, -1), (0, 1)])
a_front = box(3.5, -0.5, 5.0, 0.5) # touches front bumper
b_rear = box(-1.0, -0.5, 0.5, 0.5) # touches rear bumper
def current(actors): # same structure as collision.py L45-56
for p in actors:
f, r, l = False, False, False
if p.intersects(front_bumper): f = True
elif p.intersects(rear_bumper): r = True
else: l = True
return f, r, l
print(current([a_front, b_rear])) # (False, True, False) front contact lost
print(current([b_rear, a_front])) # (True, False, False) rear contact lost
We also reproduced this with the real CollisionScorer and eval.data ActorPolygons using synthetic boxes. Mixed contacts keep a single class:
| Contacts in the same timestep | Class kept |
| front + rear | front only |
| front + lateral | lateral only |
| rear + lateral | lateral only |
| front + rear + lateral | lateral only |
With the same front+rear contact, mirroring the layout or flipping the ego heading changes which class survives.
Expected behavior Per-timestep flags are the OR over all intersecting actors, and they do not depend on iteration order, spatial layout or ego heading. Single-actor results stay as they are.
Suggested fix: initialise the three flags once before the loop, keep the per-actor if front / elif rear / else lateral rule, and append once per timestep. With this change, all the cases above return the union, collision_any does not change, and single-actor results are identical.
Environment overview (please complete the following information)
- Deployment: Docker Compose (single machine)
- Renderer backend: NuRec (default)
- Driving policy under test: custom (end-to-end student policy). The scorer bug is independent of the policy.
- Scene / dataset used: NuRec scenes from the PhysicalAI-AV set. The bug is reproducible with synthetic boxes alone, without any scene.
- Affected gRPC service(s), and image/tag if applicable: none. This is offline eval (
src/eval,CollisionScorer). Imagealpasim-base:0.134.0, commitaffc2ea.
Environment details
- Hardware: NVIDIA GB10 (DGX Spark), 1 GPU, unified memory
- Operating System: Ubuntu 24.04.4 LTS (aarch64)
- CUDA / NVIDIA driver version: CUDA 13.0, driver 580.159.03
- Docker / Docker Compose versions: Docker 29.2.1, Docker Compose v5.0.2
Additional context
- Open PR #234 ( Fix collision category accumulation across simultaneous actor contacts by erkara · Pull Request #234 · NVlabs/alpasim · GitHub ) proposes the same fix. We confirm the issue and the fix independently.
- A regression test that only permutes the actor list may not catch this, because the STRtree order does not follow list order. A mirrored-layout or flipped-heading case does catch it.
- In our closed-loop runs, multi-actor overlaps were rare, but at least one rollout flipped its pass/fail outcome.
