Hi everyone,
Does anybody tried to install colmap on a Jetson Nano?
I’m following the instructions as Build from source - Linux, but I have this error when compiling:
Scanning dependencies of target colmap
[ 54%] Building CXX object src/CMakeFiles/colmap.dir/ui/automatic_reconstruction_widget.cc.o
In file included from /home/dani/colmap/src/ui/main_window.h:51:0,
from /home/dani/colmap/src/ui/automatic_reconstruction_widget.cc:33:
/home/dani/colmap/src/ui/model_viewer_widget.h:55:63: error: expected class-name before ‘{’ token
protected QOpenGLFunctions_3_2_Core {
src/CMakeFiles/colmap.dir/build.make:1718: recipe for target ‘src/CMakeFiles/colmap.dir/ui/automatic_reconstruction_widget.cc.o’ failed
make[2]: *** [src/CMakeFiles/colmap.dir/ui/automatic_reconstruction_widget.cc.o] Error 1
CMakeFiles/Makefile2:1000: recipe for target ‘src/CMakeFiles/colmap.dir/all’ failed
make[1]: *** [src/CMakeFiles/colmap.dir/all] Error 2
Makefile:129: recipe for target ‘all’ failed
make: *** [all] Error 2
Hi… Good news!!!
I’ve been able to build colmap after compile QT5 from scratch (following Building Qt 5 from Git - Qt Wiki ).
I’m still having problems with some libraries, but now I can run colmap (only command line, no GUI).
I also started with the installation of colmap on my Jetson Nano.
I used the “jetson-nano-sd-r32.2-2019-07-16.img” image and followed the official installation guide form here Installation — COLMAP 3.8 documentation.
I followed each step as described in the colmap guide.
But now after executing the “cmake …” command I got the following error and I am not sure what to do right now.
nano@nano:~/colmap/build$ cmake ..
CMake Error at CMakeLists.txt:87 (find_package):
By not providing "FindCeres.cmake" in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by "Ceres", but
CMake did not find one.
Could not find a package configuration file provided by "Ceres" with any of
the following names:
CeresConfig.cmake
ceres-config.cmake
Add the installation prefix of "Ceres" to CMAKE_PREFIX_PATH or set
"Ceres_DIR" to a directory containing one of the above files. If "Ceres"
provides a separate development package or SDK, be sure it has been
installed.
-- Configuring incomplete, errors occurred!
See also "/home/nano/colmap/build/CMakeFiles/CMakeOutput.log".
Maybe somebody has a hint for me how to execute the cmake … command or how to edit the “CMAKE_MODULE_PATH”…
This are the commands I executed to install everything as described.
