example:
this picture generate by script:
gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM),width=1920, height=1080, framerate=30/1' ! nvjpegenc ! filesink location=test.jpg
And in my opencv application, our script is:
nvarguscamerasrc ! video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, framerate=(fraction)30/1 ! nvvidconv flip-method=0 ! video/x-raw, width=(int)1920, height=(int)1080, format=(string)BGRx ! videoconvert ! video/x-raw, format=(string)BGR ! appsink
for camera detail:
v4l2-ctl -d /dev/video0 --all
Driver Info:
Driver name : tegra-video
Card type : vi-output, imx390 9-0020
Bus info : platform:tegra-capture-vi:1
Driver version : 5.10.120
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Media Driver Info:
Driver name : tegra-camrtc-ca
Model : NVIDIA Tegra Video Input Device
Serial :
Bus info :
Media version : 5.10.120
Hardware revision: 0x00000003 (3)
Interface Info:
Type : V4L Video
Entity Info:
Name : vi-output, imx390 9-0020
Function : V4L2 I/O
Pad 0x0100000a : 0: Sink
Link 0x0200000f: from remote pad 0x1000003 of entity '13e40000.host1x:nvcsi@15a00000-': Data, Enabled
Priority: 2
Video input : 0 (Camera 1: no power)
Format Video Capture:
Width/Height : 1920/1080
Pixel Format : 'RG12' (12-bit Bayer RGRG/GBGB)
Field : None
Bytes per Line : 3840
Size Image : 4147200
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Full Range)
Flags :
Camera Controls
group_hold 0x009a2003 (bool) : default=0 value=0 flags=execute-on-write
hdr_enable 0x009a2004 (intmenu): min=0 max=1 default=0 value=0
0: 0 (0x0)
1: 1 (0x1)
sensor_mode 0x009a2008 (int64) : min=0 max=1 step=1 default=0 value=0 flags=slider
gain 0x009a2009 (int64) : min=0 max=30000 step=300 default=1 value=16800 flags=slider
exposure 0x009a200a (int64) : min=2999 max=3000 step=1 default=3000 value=3000 flags=slider
frame_rate 0x009a200b (int64) : min=30000000 max=30000000 step=1 default=30000000 value=30000000 flags=slider
exposure_short 0x009a200c (int64) : min=3000 max=3000 step=1 default=3000 value=3000 flags=slider
sensor_configuration 0x009a2032 (u32) : min=0 max=4294967295 step=1 default=0 [22] flags=read-only, volatile, has-payload
sensor_mode_i2c_packet 0x009a2033 (u32) : min=0 max=4294967295 step=1 default=0 [1026] flags=read-only, volatile, has-payload
sensor_control_i2c_packet 0x009a2034 (u32) : min=0 max=4294967295 step=1 default=0 [1026] flags=read-only, volatile, has-payload
bypass_mode 0x009a2064 (intmenu): min=0 max=1 default=0 value=1
0: 0 (0x0)
1: 1 (0x1)
override_enable 0x009a2065 (intmenu): min=0 max=1 default=0 value=1
0: 0 (0x0)
1: 1 (0x1)
height_align 0x009a2066 (int) : min=1 max=16 step=1 default=1 value=1
size_align 0x009a2067 (intmenu): min=0 max=2 default=0 value=0
0: 1 (0x1)
1: 65536 (0x10000)
2: 131072 (0x20000)
write_isp_format 0x009a2068 (int) : min=1 max=1 step=1 default=1 value=1
sensor_signal_properties 0x009a2069 (u32) : min=0 max=4294967295 step=1 default=0 [30][18] flags=read-only, has-payload
sensor_image_properties 0x009a206a (u32) : min=0 max=4294967295 step=1 default=0 [30][16] flags=read-only, has-payload
sensor_control_properties 0x009a206b (u32) : min=0 max=4294967295 step=1 default=0 [30][36] flags=read-only, has-payload
sensor_dv_timings 0x009a206c (u32) : min=0 max=4294967295 step=1 default=0 [30][16] flags=read-only, has-payload
low_latency_mode 0x009a206d (bool) : default=0 value=0
preferred_stride 0x009a206e (int) : min=0 max=65535 step=1 default=0 value=0
sensor_modes 0x009a2082 (int) : min=0 max=30 step=1 default=30 value=1 flags=read-only
it’s a 12-bit Bayer RGRG/GBGB input CSI camera, but with multi debugging, image also looks like closer to green, such as x-bayer, format=nv12 or format=grrb also not useful. what’s the right way to do?
