• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 7.0
• NVIDIA GPU Driver Version (valid for GPU only) 551.76
• Issue Type( questions, new requirements, bugs) Question
Is it possible to combine three classes (car, bus, truck) into class of vehicle using deepstream. Because sometimes YOLO changes detected object’s class and tracker assigns new id to it.
• TensorRT Version
what do you mean about “combine three classes (car, bus, truck) into class of vehicle using deepstream” and “YOLO changes detected object’s class”? deepstream is used to do inference with NVIDIA GPU acceleration. it will not modify the model’s classification.
No, I mean there are cases, when YOLO mistakenly classifies a car as a truck or a bus, and when it happens, tracker changes car’s id. And I don’t need to distinguish a car from a truck. I just wanted to know is it possible change pgie configuration so it will solve this problem.
I just edited my custom lib so it solved this problem. Thanks.
