Combining frames into channels in DS5
Hi!
I’ve got a problem that I would appreciate some help with.
There is a DeepStream pipeline for Xavier AGX where I need to collect 3 consequtive RGB frames, take RED channels out of them and combine these channels into a single frame that will be passed to the inference engine and forth. The idea is to get some dynamics along channels dimension.
What would be the best starting point and direction to move?
So far I attempt to play with test1_rtsp_out example and got it working with custom network and bbox parser.
Many thanks in advance!
Sergey
Dets:
Jetson AGX Xavier
• DeepStream Version
5.1
JetPack 4.5.1 GA
• TensorRT Version
7.1.3-1+cuda10.2
Here is the script so far:
#!/usr/bin/env python3
import argparse
import sys
sys.path.append('../')
import gi
gi.require_version('Gst', '1.0')
gi.require_version('GstRtspServer', '1.0')
from gi.repository import GObject, Gst, GstRtspServer
from common.is_aarch_64 import is_aarch64
from common.bus_call import bus_call
import pyds
def osd_sink_pad_buffer_probe(pad,info,u_data):
    frame_number=0
    obj_counter = dict(zip(range(80),range(80)))
    num_rects=0
    gst_buffer = info.get_buffer()
    if not gst_buffer:
        print("Unable to get GstBuffer ")
        return
    # Retrieve batch metadata from the gst_buffer
    # Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
    # C address of gst_buffer as input, which is obtained with hash(gst_buffer)
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
    l_frame = batch_meta.frame_meta_list
    while l_frame is not None:
        try:
            # Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
            # The casting is done by pyds.NvDsFrameMeta.cast()
            # The casting also keeps ownership of the underlying memory
            # in the C code, so the Python garbage collector will leave
            # it alone.
        except StopIteration:
            break
        frame_number=frame_meta.frame_num
        num_rects = frame_meta.num_obj_meta
        print("num_rects: {}".format(num_rects))
        l_obj=frame_meta.obj_meta_list
        while l_obj is not None:
            try:
                # Casting l_obj.data to pyds.NvDsObjectMeta
                obj_meta=pyds.NvDsObjectMeta.cast(l_obj.data)
                break
            obj_counter[obj_meta.class_id] += 1
            try:
                l_obj=l_obj.next
                break
        # Acquiring a display meta object. The memory ownership remains in
        # the C code so downstream plugins can still access it. Otherwise
        # the garbage collector will claim it when this probe function exits.
        display_meta=pyds.nvds_acquire_display_meta_from_pool(batch_meta)
        display_meta.num_labels = 1
        py_nvosd_text_params = display_meta.text_params[0]
        # Setting display text to be shown on screen
        # Note that the pyds module allocates a buffer for the string, and the
        # memory will not be claimed by the garbage collector.
        # Reading the display_text field here will return the C address of the
        # allocated string. Use pyds.get_string() to get the string content.
        py_nvosd_text_params.display_text = "Frame Number={} Number of Objects={} Vehicle_count={} Person_count={}".format(frame_number, num_rects, obj_counter[PGIE_CLASS_ID_CAR], obj_counter[PGIE_CLASS_ID_PERSON])
        # Now set the offsets where the string should appear
        py_nvosd_text_params.x_offset = 10
        py_nvosd_text_params.y_offset = 12
        # Font , font-color and font-size
        py_nvosd_text_params.font_params.font_name = "Serif"
        py_nvosd_text_params.font_params.font_size = 10
        # set(red, green, blue, alpha); set to White
        py_nvosd_text_params.font_params.font_color.set(1.0, 1.0, 1.0, 1.0)
        # Text background color
        py_nvosd_text_params.set_bg_clr = 1
        # set(red, green, blue, alpha); set to Black
        py_nvosd_text_params.text_bg_clr.set(0.0, 0.0, 0.0, 1.0)
        # Using pyds.get_string() to get display_text as string
        print(pyds.get_string(py_nvosd_text_params.display_text))
        pyds.nvds_add_display_meta_to_frame(frame_meta, display_meta)
        try:
            l_frame=l_frame.next
            break
    return Gst.PadProbeReturn.OK
def main(args):
    # Standard GStreamer initialization
    GObject.threads_init()
    Gst.init(None)
    # Create gstreamer elements
    # Create Pipeline element that will form a connection of other elements
    print("Creating Pipeline \n ")
    pipeline = Gst.Pipeline()
    if not pipeline:
        sys.stderr.write(" Unable to create Pipeline \n")
   # Source element for reading from the file
    print("Creating Source \n ")
    source = Gst.ElementFactory.make("v4l2src", "usb-cam-source")
    if not source:
        sys.stderr.write(" Unable to create Source \n")
    caps_v4l2src = Gst.ElementFactory.make("capsfilter", "v4l2src_caps")
    if not caps_v4l2src:
        sys.stderr.write(" Unable to create v4l2src capsfilter \n")
    print("Creating Video Converter \n")
    # Adding videoconvert -> nvvideoconvert as not all
    # raw formats are supported by nvvideoconvert;
    # Say YUYV is unsupported - which is the common
    # raw format for many logi usb cams
    # In case we have a camera with raw format supported in
    # nvvideoconvert, GStreamer plugins' capability negotiation
    # shall be intelligent enough to reduce compute by
    # videoconvert doing passthrough (TODO we need to confirm this)
    # videoconvert to make sure a superset of raw formats are supported
    vidconvsrc = Gst.ElementFactory.make("videoconvert", "convertor_src1")
    if not vidconvsrc:
        sys.stderr.write(" Unable to create videoconvert \n")
    # nvvideoconvert to convert incoming raw buffers to NVMM Mem (NvBufSurface API)
    nvvidconvsrc = Gst.ElementFactory.make("nvvideoconvert", "convertor_src2")
    if not nvvidconvsrc:
        sys.stderr.write(" Unable to create Nvvideoconvert \n")
    caps_vidconvsrc = Gst.ElementFactory.make("capsfilter", "nvmm_caps")
    if not caps_vidconvsrc:
        sys.stderr.write(" Unable to create capsfilter \n")
    # Create nvstreammux instance to form batches from one or more sources.
    streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
    if not streammux:
        sys.stderr.write(" Unable to create NvStreamMux \n")
    # Use nvinfer to run inferencing on decoder's output,
    # behaviour of inferencing is set through config file
    pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
    if not pgie:
        sys.stderr.write(" Unable to create pgie \n")
    # Use convertor to convert from NV12 to RGBA as required by nvosd
    nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
    if not nvvidconv:
        sys.stderr.write(" Unable to create nvvidconv \n")
    # Create OSD to draw on the converted RGBA buffer
    nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
    if not nvosd:
        sys.stderr.write(" Unable to create nvosd \n")
    nvvidconv_postosd = Gst.ElementFactory.make("nvvideoconvert", "convertor_postosd")
    if not nvvidconv_postosd:
        sys.stderr.write(" Unable to create nvvidconv_postosd \n")
    # Create a caps filter
    caps = Gst.ElementFactory.make("capsfilter", "filter")
    caps.set_property("caps", Gst.Caps.from_string("video/x-raw(memory:NVMM), format=I420"))
    # Make the encoder
    if codec == "H264":
        encoder = Gst.ElementFactory.make("nvv4l2h264enc", "encoder")
        print("Creating H264 Encoder")
    elif codec == "H265":
        encoder = Gst.ElementFactory.make("nvv4l2h265enc", "encoder")
        print("Creating H265 Encoder")
    if not encoder:
        sys.stderr.write(" Unable to create encoder")
    encoder.set_property('bitrate', bitrate)
    if is_aarch64():
        encoder.set_property('preset-level', 1)
        encoder.set_property('insert-sps-pps', 1)
        encoder.set_property('bufapi-version', 1)
    # Make the payload-encode video into RTP packets
    if codec == "H264":
        rtppay = Gst.ElementFactory.make("rtph264pay", "rtppay")
        print("Creating H264 rtppay")
        rtppay = Gst.ElementFactory.make("rtph265pay", "rtppay")
        print("Creating H265 rtppay")
    if not rtppay:
        sys.stderr.write(" Unable to create rtppay")
    # Make the UDP sink
    updsink_port_num = 5400
    sink = Gst.ElementFactory.make("udpsink", "udpsink")
    if not sink:
        sys.stderr.write(" Unable to create udpsink")
    #sink.set_property('host', '224.224.255.255')
    sink.set_property('host', '192.168.1.190')
    sink.set_property('port', updsink_port_num)
    sink.set_property('async', False)
    sink.set_property('sync', 1)
    print("Playing file %s " %stream_path)
#    source.set_property('location', stream_path)
    caps_v4l2src.set_property('caps', Gst.Caps.from_string("video/x-raw "))
    caps_vidconvsrc.set_property('caps', Gst.Caps.from_string("video/x-raw(memory:NVMM)"))
    source.set_property('device', stream_path)
    streammux.set_property('width', 1920)
    streammux.set_property('height', 1080)
    streammux.set_property('batch-size', 1)
    streammux.set_property('batched-push-timeout', 4000000)
    pgie.set_property('config-file-path', "dstest1_pgie_config.txt")
    print("Adding elements to Pipeline \n")
#    pipeline.add(h264parser)
#    pipeline.add(decoder)
    pipeline.add(source)
    pipeline.add(caps_v4l2src)
    pipeline.add(vidconvsrc)
    pipeline.add(nvvidconvsrc)
    pipeline.add(caps_vidconvsrc)
    pipeline.add(streammux)
    pipeline.add(pgie)
    pipeline.add(nvvidconv)
    pipeline.add(nvosd)
    pipeline.add(nvvidconv_postosd)
    pipeline.add(caps)
    pipeline.add(encoder)
    pipeline.add(rtppay)
    pipeline.add(sink)
    # Link the elements together:
    print("Linking elements in the Pipeline \n")
    source.link(caps_v4l2src)
    caps_v4l2src.link(vidconvsrc)
    vidconvsrc.link(nvvidconvsrc)
    nvvidconvsrc.link(caps_vidconvsrc)
    sinkpad = streammux.get_request_pad("sink_0")
    if not sinkpad:
        sys.stderr.write(" Unable to get the sink pad of streammux \n")
    srcpad = caps_vidconvsrc.get_static_pad("src")
    if not srcpad:
        sys.stderr.write(" Unable to get source pad of caps_vidconvsrc \n")
    srcpad.link(sinkpad)
    streammux.link(pgie)
    pgie.link(nvvidconv)
    nvvidconv.link(nvosd)
    nvosd.link(nvvidconv_postosd)
    nvvidconv_postosd.link(caps)
    caps.link(encoder)
    encoder.link(rtppay)
    rtppay.link(sink)
    # create an event loop and feed gstreamer bus mesages to it
    loop = GObject.MainLoop()
    bus = pipeline.get_bus()
    bus.add_signal_watch()
    bus.connect ("message", bus_call, loop)
    # Start streaming
    rtsp_port_num = 8554
    server = GstRtspServer.RTSPServer.new()
    server.props.service = "%d" % rtsp_port_num
    server.attach(None)
    factory = GstRtspServer.RTSPMediaFactory.new()
    factory.set_launch( "( udpsrc name=pay0 port=%d buffer-size=524288 caps=\"application/x-rtp, media=video, clock-rate=90000, encoding-name=(string)%s, payload=96 \" )" % (updsink_port_num, codec))
    factory.set_shared(True)
    server.get_mount_points().add_factory("/ds-test", factory)
    print("\n *** DeepStream: Launched RTSP Streaming at rtsp://localhost:%d/ds-test ***\n\n" % rtsp_port_num)
    # Lets add probe to get informed of the meta data generated, we add probe to
    # the sink pad of the osd element, since by that time, the buffer would have
    # had got all the metadata.
    osdsinkpad = nvosd.get_static_pad("sink")
    if not osdsinkpad:
        sys.stderr.write(" Unable to get sink pad of nvosd \n")
    osdsinkpad.add_probe(Gst.PadProbeType.BUFFER, osd_sink_pad_buffer_probe, 0)
    # start play back and listen to events
    print("Starting pipeline \n")
    pipeline.set_state(Gst.State.PLAYING)
    try:
        loop.run()
    except:
        pass
    # cleanup
    pipeline.set_state(Gst.State.NULL)
def parse_args():
    parser = argparse.ArgumentParser(description='RTSP Output Sample Application Help ')
    parser.add_argument("-i", "--input",
                  help="Path to input H264 elementry stream", required=True)
    parser.add_argument("-c", "--codec", default="H264",
                  help="RTSP Streaming Codec H264/H265 , default=H264", choices=['H264','H265'])
    parser.add_argument("-b", "--bitrate", default=4000000,
                  help="Set the encoding bitrate ", type=int)
    # Check input arguments
    if len(sys.argv)==1:
        parser.print_help(sys.stderr)
        sys.exit(1)
    args = parser.parse_args()
    global codec
    global bitrate
    global stream_path
    codec = args.codec
    bitrate = args.bitrate
    stream_path = args.input
    return 0
if __name__ == '__main__':
    parse_args()
    sys.exit(main(sys.argv))
Current nvinfer plugin does not support buffering frames for handling consequtive frames. So you need to develop your own inference plugin to handle such case.
The good start point is to learn gstreamer basic knowledge and coding skills first for the customization may need deep gstreamer skills along with deepstream skills.
Python will not help your case. You need c/c++ skills too.
