ComfyUI should work on a DGX Spark. Wondering if ComfyUI will work with two hooked together with NVlink.
I expect it would be like any other multi-GPU system. Separate jobs can run on either Spark, and an entire copy of the model would need to fit on each Spark individually. I doubt the linked system would present as one GPU.
Does eXo work with ComfyUI?
Oooo. That is a good question. If DGX OS is ubuntu based I don’t see why not.
Got this a day or so ago from Comfy.org
NVIDIA just released NVIDIA DGX Spark. For those who don’t know this is a small form factor computer similar in size to a NUC or a Mac mini. What is special with this one is that both the CPU and GPU are in a single unit made by Nvidia and it has 128GB of unified memory that can be both ram and vram.
NVIDIA DGX Spark supports running ComfyUI extremely well. All the models I have tried work. It’s running Linux so to install ComfyUI on it you can just follow the regular NVIDIA instructions in our readme.
Performance wise it doesn’t beat a full desktop with a 5090 but it can run models and workloads that are too large for even high-end desktop systems.
