Command for flashing jetson AGX Xavier 64GB module - L4T R35.5.0
What is the BSP flash command for Jetson AGX Xavier 64GB module. I wanted to flash L4T35.5.0.
Please refer to Flashing Support — NVIDIA Jetson Linux Developer Guide 1 documentation
I saw that document.
I am using the below command for Jetson AGX xavier 32GB module.
sudo ./flash.sh jetson-xavier mmcblk0p1
Will the same command work for AGX Xavier 64GB module or do we have any other specific command for 64GB module.
I tried flashing the 64GB module with same command as 32GB module (sudo ./flash.sh jetson-xavier mmcblk0p1). Flashing is successful but the device is not booting.
Give the log of the device is not booting.
Hi Dave,
Below is the hostlog and Debug uart log. Some initial log is missing.
AGX_Xavier_64GB_debug_uart_log.txt (57.6 KB)
AGX_Xavier_64GB_hostlog_log.txt (615.2 KB)
Flash again and capture the full log.
Hi Dave,
Yes, sure will capture the full log. Can you please confirm me on the command. Can I use the command “sudo ./flash.sh jetson-xavier mmcblk0p1” for flashing AGX Xavier 64GB module or is there any other command for 64GB module.
YES.
They are the same.
