Command-line error #571: invalid option: --orig_src_file_name
I am trying to build this repo on my RTX 4070.
https://github.com/ggerganov/llama.cpp#cublas
Output of :
nvcc --version
Copyright (c) 2005-2023 NVIDIA Corporation
Built on Fri_Sep__8_19:17:24_PDT_2023
Cuda compilation tools, release 12.3, V12.3.52
Build cuda_12.3.r12.3/compiler.33281558_0
which nvcc
/usr/bin/nvcc
/usr/bin/nvcc --version
nvidia-smi
| NVIDIA-SMI 545.23.06 Driver Version: 545.23.06 CUDA Version: 12.3 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 4070 On | 00000000:2B:00.0 On | N/A |
| 0% 38C P8 7W / 200W | 714MiB / 12282MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1057 G /usr/lib/xorg/Xorg 71MiB |
| 0 N/A N/A 1710 G /usr/lib/xorg/Xorg 364MiB |
| 0 N/A N/A 1836 G /usr/bin/gnome-shell 44MiB |
| 0 N/A N/A 2822 G …3435456,12867152336119127528,262144 211MiB |
Ubuntu 20.04.6 LTS
In the root directory of this repo, I run this command to compile:
make LLAMA_CUBLAS=1
but I get this error:
I llama.cpp build info:
I UNAME_S: Linux
I UNAME_P: x86_64
I UNAME_M: x86_64
I CFLAGS: -I. -Icommon -D_XOPEN_SOURCE=600 -D_GNU_SOURCE -DNDEBUG -DGGML_USE_CUBLAS -I/usr/local/cuda/include -I/opt/cuda/include -I/targets/x86_64-linux/include -std=c11 -fPIC -O3 -Wall -Wextra -Wpedantic -Wcast-qual -Wno-unused-function -Wshadow -Wstrict-prototypes -Wpointer-arith -Wmissing-prototypes -Werror=implicit-int -Werror=implicit-function-declaration -Wdouble-promotion -pthread -march=native -mtune=native
I CXXFLAGS: -I. -Icommon -D_XOPEN_SOURCE=600 -D_GNU_SOURCE -DNDEBUG -DGGML_USE_CUBLAS -I/usr/local/cuda/include -I/opt/cuda/include -I/targets/x86_64-linux/include -std=c++11 -fPIC -O3 -Wall -Wextra -Wpedantic -Wcast-qual -Wno-unused-function -Wmissing-declarations -Wmissing-noreturn -pthread -Wno-array-bounds -Wno-format-truncation -Wextra-semi -march=native -mtune=native
I NVCCFLAGS: --forward-unknown-to-host-compiler -use_fast_math -arch=compute_89 -DGGML_CUDA_DMMV_X=32 -DGGML_CUDA_MMV_Y=1 -DK_QUANTS_PER_ITERATION=2 -DGGML_CUDA_PEER_MAX_BATCH_SIZE=128 -I. -Icommon -D_XOPEN_SOURCE=600 -D_GNU_SOURCE -DNDEBUG -DGGML_USE_CUBLAS -I/usr/local/cuda/include -I/opt/cuda/include -I/targets/x86_64-linux/include -std=c++11 -fPIC -O3 -Wall -Wextra -Wpedantic -Wcast-qual -Wno-unused-function -Wmissing-declarations -Wmissing-noreturn -pthread -Wno-pedantic -Xcompiler "-Wno-array-bounds -Wno-format-truncation -Wextra-semi -march=native -mtune=native "
I LDFLAGS: -lcublas -lculibos -lcudart -lcublasLt -lpthread -ldl -lrt -L/usr/local/cuda/lib64 -L/opt/cuda/lib64 -L/targets/x86_64-linux/lib
I CC: cc (Ubuntu 8.4.0-3ubuntu2) 8.4.0
I CXX: g++ (Ubuntu 8.4.0-3ubuntu2) 8.4.0
nvcc --forward-unknown-to-host-compiler -use_fast_math -arch=compute_89 -DGGML_CUDA_DMMV_X=32 -DGGML_CUDA_MMV_Y=1 -DK_QUANTS_PER_ITERATION=2 -DGGML_CUDA_PEER_MAX_BATCH_SIZE=128 -I. -Icommon -D_XOPEN_SOURCE=600 -D_GNU_SOURCE -DNDEBUG -DGGML_USE_CUBLAS -I/usr/local/cuda/include -I/opt/cuda/include -I/targets/x86_64-linux/include -std=c++11 -fPIC -O3 -Wall -Wextra -Wpedantic -Wcast-qual -Wno-unused-function -Wmissing-declarations -Wmissing-noreturn -pthread -Wno-pedantic -Xcompiler "-Wno-array-bounds -Wno-format-truncation -Wextra-semi -march=native -mtune=native " -c ggml-cuda.cu -o ggml-cuda.o
1 catastrophic error detected in this compilation.
Compilation terminated.
make: *** [Makefile:451: ggml-cuda.o] Error 4
I tried grepping this --orig_src_file_name but could not found in any source file. Only binary files are listed while finding this.
Please help me with this.
Thanks in advance.
