Command not found when ./Makefile is executed
I run ./Makefile but then I got messages:
./Makefile line xx: EXECUTABLE: command not found
CUFILES
and CCFILES, include and so on
That is probably question about basic stuff but I am still a rookie in Linux environment and GPU computing.
Just type “make” (without the quotation marks). The program “make” will then look for a file called “Makefile” and use it as its input :)
yes, Makefile is just a script that tells the program ‘make’ how to build the program.
