I’ve just donwloaded and installed a trial version of PGI workstation: the installation (Ubuntu 12.10 x64) returned no errors and I can see the files in the standard directory. I’ve installed the program as root (sudo ./install) and set my license key using the environmental variable (export LM_LICENSE_FILE=path to the .dat folder)
Problem is if I type pgcc (or any other compiler command) the shell returns a “No command found”, how’s it? Do I need to source the commands? Do something else? Did I miss a step?
