Hi, I need to customize INvDsInPlaceDataHandler. What is the correct command to use?
python3 /opt/nvidia/graph-composer/extension-dev/generate_codelet.py
–output_dir /tmp/ --extn_name test --codelet_name HelloWorld
or
python3 /opt/nvidia/deepstream/deepstream/tools/graph_extension_generator/generate_extensions.py <element_list.txt>
Could you please confirm?
What is the element list (element_list.txt) of this class to include?
Which file can I include the INvDsInPlaceDataHandler
code in?
Actually this command is for this purpose Extension Development Workflow — DeepStream documentation
For your INvDsInPlaceDataHandler customization extension, there is no tool to help you to generate the correct bazel project.
As I’ve told you in another topic, there is no proper sample for your case now. We will consider your request in future.
system
Closed
8
