I encountered Command Buffer Full
in nsight systems log. It happens only on H100 and not A100 and I wanted to find out why.
So I found out CUPTI has this CUpti_ActivityOverheadCommandBufferFullData data structure and I was hoping I could get some info out of it.
I modified the sample cuda file activity_trace_async/activity_trace_async.cu
, added some code to send a lot kernels to GPU and successfully triggered COMMAND_BUFFER_FULL on H100.
But all I got was something like:
OVERHEAD COMMAND_BUFFER_FULL [ 1730095755645170274, 1730095755645707410 ] duration 537136, THREAD, id 2027675648, correlation id 42169
CUpti_ActivityOverheadCommandBufferFullData : commandBufferLength 0 channelID 10 channelType 0
OVERHEAD COMMAND_BUFFER_FULL [ 1730095755645713971, 1730095755646239164 ] duration 525193, THREAD, id 2027675648, correlation id 42170
Is this the correct behavior? Does that mean this GPU has effectively no commandBuffer (commandBufferLength 0)?
or does it mean the buffer length is exhausted, which seems meaningless if this is only triggered when command buffer is full.
On the other hand, when I ran the same thing on A100, I didn’t get any COMMAND_BUFFER_FULL
. Is there a way to find out the command buffer length without triggering a command buffer full event?
I used cuda 12.6.2 btw:
wget https://developer.download.nvidia.com/compute/cuda/12.6.2/local_installers/cuda_12.6.2_560.35.03_linux.run
