I am using jetson TX2 4GB module on my device with SDK 32.4.3.
when i see the cmdline parameter using cat /proc/cmdline i see below logs
Kernel command line: console=ttyS0,115200 * androidboot.presilicon=true* firmware_class.path=/etc/firmware root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 f
bcon=map:0 net.ifnames=0 isolcpus=1-2 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x1772e0000 gpt usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.
slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x175840000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait sdhci_tegra.en_boot_part_access=1 mem=4070M
what is this flag androidboot.presilicon=true, is this required for custom board,what is the use of this flag in kernel command line parameter.
