I have got this error “Common block variables are not supported in acc routine” when compiling. I find that there is a bug fixed report in Technical Problem Reports says
pgfortran -ta=tesla -Minline fails with “Common block variables are not supported in acc routine”
Corrected the inlining of module routines marked acc routine containing use-associated variables
I don’t quite understand what am I supposed to do exactly since there is no simple case showed. I tried to delete the ‘-Minline’ but the same errors are still there. Would you please tell me how to fix this compiling error?
Thanks,
Xiaowei.
