program main
use mpi
double precision PI25DT
parameter (PI25DT = 3.141592653589793238462643d0)
double precision mypi, pi, h, sum, x, f, a
integer n, myid, numprocs, i, ierr
! function to integrate
f(a) = 4.d0 / (1.d0 + a*a)
call MPI_INIT(ierr)
call MPI_COMM_RANK(MPI_COMM_WORLD, myid, ierr)
call MPI_COMM_SIZE(MPI_COMM_WORLD, numprocs, ierr)
do
if (myid .eq. 0) then
print *, 'Enter the number of intervals: (0 quits) '
read(*,*) n
endif
! broadcast n
call MPI_BCAST(n, 1, MPI_INTEGER, 0, MPI_COMM_WORLD, ierr)
! check for quit signal
if (n .le. 0) exit
! calculate the interval size
h = 1.0d0/n
sum = 0.0d0
do i = myid+1, n, numprocs
x = h * (dble(i) - 0.5d0)
sum = sum + f(x)
enddo
mypi = h * sum
! collect all the partial sums
call MPI_REDUCE(mypi, pi, 1, MPI_DOUBLE_PRECISION, &
MPI_SUM, 0, MPI_COMM_WORLD, ierr)
! node 0 prints the answer.
print *, 'pi is ', pi, ' Error is', abs(pi - PI25DT)
endifenddo
call MPI_FINALIZE(ierr)
end
I was able to compile with mpif90 (only use pgf77/mpif77 when
it is necessary that you use f77 features not in f90 )
mpif90 -o my_pi my_pi.f -Mfree
I then ran it with
% mpirun -np 4 my_pi
10
pi is 3.142425985001098 Error is 8.3333141130470523E-004
100
pi is 3.141600986923125 Error is 8.3333333318336145E-006
1000
pi is 3.141592736923126 Error is 8.3333333122936892E-008
10000
pi is 3.141592654423124 Error is 8.3333073774838340E-010
1000000
pi is 3.141592653589903 Error is 1.1013412404281553E-013
2000000
pi is 3.141592653589759 Error is 3.4194869158454821E-014
0
Program is similar, I made some minor changes a few years ago. As I mentioned this fails on one particular machine. It runs OK on 2 others that I tried.
The error -
request to allocate mask for invalid number; abort
The question on the failing platform is
“is libnuma.so the same on the failing platform as on
the compiling platform”
So look at
ldd ./pi
and see if
libnuma.so is a pointer to libnuma.so.1
If not, it could be that libnuma.so does not exist, but libnuma.so.1 does.
Best to soft link libnuma.so to libnuma.so.1.
If libnuma.so.1 does not exist, PGI provides a dummy version.
When compiling -mp on one platform to run on another platform,
the libnuma.so situation needs to be the same on both.
You could install the PGI compilers on one platform as a “network
install”, and then add the failing platform as a new PGI compiler
host (run add_network_host and the machine is added).
The network installs handle the libnuma.so differences by creating
a local directory of the same name on each platform. For example " /local/username/shared_objects" would have the correct
disposition of libnuma.so (pointer to libnuma.so.1 or a dummy version of libnuma.so.1) Then every platform reconciles libnuma.so
correctly at runtime.
