Therefore, provided that for testing the different storage options are not an issue, is it possible to use the P3448-0000 SOM Variant in a custom carrier board with no EEPROM ID.
Any help into this matter would be greatly appreciated.
Thanks for your reply.
But as detailed in the document above an EEPROM ID is not requited for our custom Carrier board if we are using the p3448-0002 SOM variant right ?
They are sharing same i2c bus but different address. There is no need for custom board eeprom. But the eeprom on SOM is needed. You cannot just totally disable that i2c from device tree.
