Compatibility Check: Jetson Nano 2GB with JETSON-IO-BASE-LITE Carrier Board
I have a Jetson Nano 2GB (model: P3448 180-13448-DAAA-B01) with a carrier board (model: P3541 180-13542-DAAF-A02). My current carrier board has some hardware issues and needs to be replaced.
I want to know if the JETSON-IO-BASE-LITE carrier board from Waveshare (https://www.waveshare.com/jetson-nano-lite-dev-kit.htm?sku=23605) is compatible with my Jetson Nano 2GB module.
The major thing is BSP SW image support, you may need to check with Waveshare to know that.
