Hi everyone,
I am planning to build a local, offline interactive avatar project running on a NVIDIA Jetson Orin Nano (8GB) or Orin Nx, and I would like to get confirmation from the community regarding hardware and software compatibility before purchasing the board.
The system acts as a digital avatar of a painting (using looping MP4 videos coordinated with audio) powered entirely on-edge. Here is the exact technology stack I intend to use:
AI Models & Services
- Local LLM: Gemma 2 2B Instruct (GGUF format, Q4_K_M quantization). Served via
llama.cppusing the CUDA-accelerated server image (ghcr.io/ggml-org/llama.cpp:server-cuda) with GPU offload (-ngl) and a context window of 8192 tokens. - Local STT (Speech-to-Text):
faster-whisper(using thesmallmodel for Italian, CPU computation withint8). - Local TTS (Text-to-Speech):
- Option A: Piper TTS (ONNX models, running on CPU).
- Option B: Kokoro TTS (
hexgrad/Kokoro-82M, PyTorch, soundfile, espeak-ng, running with GPU/CUDA acceleration).
- Embeddings & RAG:
Xenova/multilingual-e5-smallvia@huggingface/transformers(384 dimensions).
Backend, Database & Infrastructure
- Backend API: Node.js 22 + Express.
- Database & Vector Search: PostgreSQL 15 with the native pgvector extension running inside Docker (used for semantic search/RAG over museum documents, avoiding external vector DBs).
- Frontend: Angular 17 running in a browser kiosk mode (handles webcam/audio capture and plays local MP4 video loops for the avatar states).
- Orchestration: Docker & Docker Compose (using the NVIDIA container runtime).
My Questions:
- Given the 8GB shared memory of the Jetson Orin Nano, will this full-local stack (PostgreSQL + pgvector, llama.cpp with a 2B model, faster-whisper, and TTS) comfortably fit within the limits without running out of RAM/VRAM?
- Are there any known ARM64 / JetPack compatibility issues with
faster-whisper(CTranslate2), PyTorch (for Kokoro), or thellama.cppCUDA container on the Orin Nano? - If any of these specific technologies present a known bottleneck or compatibility issue on Jetson, what are the recommended drop-in alternative components (especially for lightweight TTS and STT) that guarantee native ARM64/CUDA execution while keeping the memory footprint minimal?
Any feedback or advice before I purchase the hardware would be greatly appreciated. Thank you!
