For a project, i’m planning to use AVerMedia D315 Carrier Board which has Jetson AGX Orin Module and e-con Systems STURDeCAM31_CUOAGX camera.
On their relative websites it’s said that D315 comes with Jetpack 6.0 L4T35.4.1 BSP and camera has support for Jetpack 6.0 L4T36.3.0. Would it be possible for me to use these devices together? Would i have any compatibility issues?
D315: https://www.avermedia.com/professional/product-detail/D315
STURDeCAM31_CUOAGX: https://www.e-consystems.com/nvidia-cameras/jetson-agx-orin-cameras/sony-isx031-ip69k-hdr-gmsl2-camera.asp
For the camera basic functionality first needs to check the device and driver configuration.
You can reference to below program guide for the detailed information of device tree and driver implementation.
https://docs.nvidia.com/jetson/archives/r36.3/DeveloperGuide/SD/CameraDevelopment/SensorSoftwareDriverProgramming.html?highlight=programing#sensor-software-driver-programming
Please refer to Applications Using V4L2 IOCTL Directly by using V4L2 IOCTL to verify basic camera functionality.
https://docs.nvidia.com/jetson/archives/r36.3/DeveloperGuide/SD/CameraDevelopment/SensorSoftwareDriverProgramming.html?highlight=programing#to-run-a-v4l2-ctl-test
Once confirm the configure and still failed below link help to get log and some information and some tips for debug.
https://elinux.org/Jetson/l4t/Camera_BringUp#Steps_to_enable_more_debug_messages
This issue will require our camera partner to do the support, let me add @velmurugan.s here to help you.
Hello @velmurugan.s ,
Still expecting to hear from you. So we can decide whether we should move forward with the camera or not.
Yes, you can use these devices together.
For more details, please reach out to us at partners@e-consystems.com
system
Closed
November 20, 2024, 5:14am
8
