XCode 4.3.1 from the App Store installs to /Applications/Xcode.app instead of /Developer. This change appears to break PGI 12.3 (and earlier, I assume).
Any help/workarounds ?
Todd
Todd
Thanks Todd, we’re working on getting a patch release out as soon as we can to address this. I’ll update this post once it’s available.
12.3 package has been fixed.
For previously installed PGI releases, please run makelocalrc -x /opt/pgi/osx86*/$version to update localrc file for Xcode 4.3.1.
If that still does not work, you will need to check if you have installed command line tools properly. Below is one way to install command line tools:
After Xcode 4.3.1 is installed.
Also, make sure your /usr/bin/xcodebuild points to the new one, command to do that:
% xcode-select -switch /Applications/Xcode.app/Contents/Developer
% /usr/bin/xcodebuild -version
Hongyon
Is this new version available for download yet?
Thanks,
Todd
