#include <iostream>
void intfun(int * pointer, int value){
#pragma acc parallel deviceptr(pointer) present(value) num_gangs(1) num_workers(1)
*pointer = value;
int main(){
int *variable_ptr;
int variable_value = 5;
#pragma acc enter data create(variable_ptr) copyin(variable_value)
#pragma acc host_data use_device(variable_ptr)
intfun(variable_ptr,variable_value);
#pragma acc exit data copyout(variable_ptr) delete(variable_value)
std::cout << *variable_ptr << std::endl;
… return the following error upon compilation?
$ pgcpp -acc main.cpp
PGCC-S-0155-Compiler failed to translate accelerator region (see -Minfo messages): Unknown variable reference (main.cpp: 6)
PGCC/x86 Linux 14.9-0: compilation completed with severe errors
While not a typical use case, your code should compile. Hence, I wrote up a report (TPR#20869) and sent it on to engineer for further investigation.
The work around is tread pointer as and array by changing “*pointer” to “pointer[0]”.
Note that since “value” is being passed by value, it is a local copy of the variable. Hence, the present clause will fail to find the variable on the device. Instead, you would need to pass “value” in by reference so it’s the same variable. Granted since “value” is just a read-only scalar, it’s unnecessary to manually copy it over to the device.
Thanks,
Mat
% cat test.cpp
#include <iostream>
#pragma acc parallel deviceptr(pointer) num_gangs(1) num_workers(1)
#ifdef WORKS
pointer[0] = value;
#else
*pointer = value;
#endif
int main(){
int *variable_ptr;
% pgcpp -acc -Minfo=accel test.cpp -DWORKS; a.out
intfun(int *, int):
5, Accelerator kernel generated
Generating Tesla code
main:
20, Generating enter data copyin(variable_value)
Accelerator clause: upper bound for dimension 0 of array 'variable_ptr' is unknown
Generating enter data create(variable_ptr[:1])
25, Generating exit data delete(variable_value)
Generating exit data copyout(variable_ptr[:1])
5
