Hello all,
not sure where to post it otherwise, so I’ll just report this way…
When building the latest Linux drivers 430.26 under a 4.19.50 vanilla kernel within a cloud virtual machine I faced following compilation error:
executing: 'cd ./kernel; /usr/bin/make -k -j8 NV_KERNEL_MODULES="nvidia" NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/opt/kernel-src" SYSOUT="/opt/kernel-src"'...
make[1]: Entering directory '/opt/kernel-src'
CC [M] /NVIDIA/kernel/nvidia/nv-pat.o
distcc[1189] (dcc_build_somewhere) Warning: failed to distribute, running locally instead
CC [M] /NVIDIA/kernel/nvidia/nv-pci-table.o
distcc[1194] (dcc_build_somewhere) Warning: failed to distribute, running locally instead
CC [M] /NVIDIA/kernel/nvidia/nv-kthread-q.o
distcc[1197] (dcc_build_somewhere) Warning: failed to distribute, running locally instead
In file included from ././include/linux/compiler_types.h:64:0,
from <command-line>:0:
/NVIDIA/kernel/nvidia/nv-pat.c: In function 'nvidia_cpu_teardown':
./include/linux/compiler-gcc.h:20:19: error: expected ';' before '__asm__'
#define barrier() __asm__ __volatile__("": : :"memory")
./include/linux/preempt.h:248:28: note: in expansion of macro 'barrier'
#define preempt_enable() barrier()
./include/linux/smp.h:203:20: note: in expansion of macro 'preempt_enable'
#define put_cpu() preempt_enable()
/NVIDIA/kernel/nvidia/nv-pat.c:147:5: note: in expansion of macro 'put_cpu'
put_cpu();
distcc[1189] ERROR: compile /NVIDIA/kernel/nvidia/nv-pat.c on localhost failed
scripts/Makefile.build:303: recipe for target '/NVIDIA/kernel/nvidia/nv-pat.o' failed
A look at the code showed the problem:
136 static int
137 nvidia_cpu_teardown(unsigned int cpu)
138 {
139 #if defined(NV_ENABLE_HOTPLUG_CPU)
140 unsigned int this_cpu = get_cpu();
141
142 if (this_cpu == cpu)
143 nv_restore_pat_entries(NULL);
144 else
145 smp_call_function(nv_restore_pat_entries, &cpu, 1)
146
147 put_cpu();
148 #endif
149 return 0;
150 }
Line 145 misses a trailing ‘;’. Adding it makes everything compile again just fine.
Funnily enough, the function ‘nvidia_cpu_online’ has similar code but does not have that error.
Hope it can get fixed, that would save us a sed-quickfix :)
Cheers from Germany,
Jonathan
