Compilation error while compiling CUDA cuSolver eigenvalue examples
I’m new to CUDA and I’m working through compiling and testing some of the examples provided by Nvidia. I am able to compile and run the example here without any issues, so I think I generally have a functioning system.
Right now, I’m trying to compile this example code which also requires the header file util.hxx at the same site. I’m compiling with the command suggested in the comments of the code itself:
nvcc -ccbin gcc -I/usr/local/cuda/include -c diag.cpp -o diag.o
I get the following errors, most of which are just variations on the same couple of errors:
In file included from diag.cpp:12:
util.hxx: In function ‘int memcpyH2D(int, const int*, int, int, const T_ELEM*, int, int, int, int, T_ELEM**, int, int)’:
util.hxx:240:49: error: there are no arguments to ‘imax’ that depend on a template parameter, so a declaration of ‘imax’ must be available [-fpermissive]
                         const int A_start_col = imax( JA, IBX_A ); /* base-1 */
util.hxx:240:49: note: (if you use ‘-fpermissive’, G++ will accept your code, but allowing the use of an undeclared name is deprecated)
util.hxx:243:42: error: there are no arguments to ‘imin’ that depend on a template parameter, so a declaration of ‘imin’ must be available [-fpermissive]
                         const int bdd  = imin( N_hat, (IBX_A + T_A -1) );
util.hxx:244:42: error: there are no arguments to ‘imin’ that depend on a template parameter, so a declaration of ‘imin’ must be available [-fpermissive]
                         const int IT_A = imin( T_A, (bdd - A_start_col + 1) );
util.hxx:249:71: error: there are no arguments to ‘IDX2F’ that depend on a template parameter, so a declaration of ‘IDX2F’ must be available [-fpermissive]
                         T_ELEM *d_A = array_d_A_unpacked[JA_blk_id] + IDX2F( loc_A_start_row, loc_A_start_col, LLD_A );
util.hxx:250:51: error: there are no arguments to ‘IDX2F’ that depend on a template parameter, so a declaration of ‘IDX2F’ must be available [-fpermissive]
                         const T_ELEM *h_A = h_B + IDX2F( A_start_row - IA + 1, A_start_col - JA + 1, ldb );
util.hxx: In function ‘int memcpyD2H(int, const int*, int, int, int, int, int, T_ELEM**, int, int, T_ELEM*, int)’:
util.hxx:328:49: error: there are no arguments to ‘imax’ that depend on a template parameter, so a declaration of ‘imax’ must be available [-fpermissive]
util.hxx:330:42: error: there are no arguments to ‘imin’ that depend on a template parameter, so a declaration of ‘imin’ must be available [-fpermissive]
util.hxx:331:42: error: there are no arguments to ‘imin’ that depend on a template parameter, so a declaration of ‘imin’ must be available [-fpermissive]
util.hxx:334:77: error: there are no arguments to ‘IDX2F’ that depend on a template parameter, so a declaration of ‘IDX2F’ must be available [-fpermissive]
                         const T_ELEM *d_A = array_d_A_unpacked[JA_blk_id] + IDX2F( loc_A_start_row, loc_A_start_col, LLD_A );
util.hxx:335:45: error: there are no arguments to ‘IDX2F’ that depend on a template parameter, so a declaration of ‘IDX2F’ must be available [-fpermissive]
util.hxx: In instantiation of ‘int memcpyH2D(int, const int*, int, int, const T_ELEM*, int, int, int, int, T_ELEM**, int, int) [with T_ELEM = double]’:
diag.cpp:53:100:   required from here
util.hxx:240:53: error: ‘imax’ was not declared in this scope
util.hxx:240:53: note: suggested alternative: ‘fmax’
                                                 fmax
util.hxx:243:46: error: ‘imin’ was not declared in this scope
util.hxx:243:46: note: suggested alternative: ‘fmin’
                                          fmin
util.hxx:244:46: error: ‘imin’ was not declared in this scope, and no declarations were found by argument-dependent lookup at the point of instantiation [-fpermissive]
util.hxx:243:46: note: ‘imin’ declared here, later in the translation unit
util.hxx:249:76: error: ‘IDX2F’ was not declared in this scope
util.hxx:249:76: note: the macro ‘IDX2F’ had not yet been defined
diag.cpp:17: note: it was later defined here
 #define IDX2F(i,j,lda) ((((j)-1)*((size_t)lda))+((i)-1))
util.hxx:250:56: error: ‘IDX2F’ was not declared in this scope, and no declarations were found by argument-dependent lookup at the point of instantiation [-fpermissive]
util.hxx:249:76: note: ‘IDX2F’ declared here, later in the translation unit
util.hxx: In instantiation of ‘int memcpyD2H(int, const int*, int, int, int, int, int, T_ELEM**, int, int, T_ELEM*, int) [with T_ELEM = double]’:
diag.cpp:242:17:   required from here
util.hxx:328:53: error: ‘imax’ was not declared in this scope
util.hxx:328:53: note: suggested alternative: ‘fmax’
                                                 fmax
util.hxx:330:46: error: ‘imin’ was not declared in this scope
util.hxx:330:46: note: suggested alternative: ‘fmin’
                                          fmin
util.hxx:331:46: error: ‘imin’ was not declared in this scope, and no declarations were found by argument-dependent lookup at the point of instantiation [-fpermissive]
util.hxx:330:46: note: ‘imin’ declared here, later in the translation unit
util.hxx:334:82: error: ‘IDX2F’ was not declared in this scope
util.hxx:334:82: note: the macro ‘IDX2F’ had not yet been defined
util.hxx:335:50: error: ‘IDX2F’ was not declared in this scope, and no declarations were found by argument-dependent lookup at the point of instantiation [-fpermissive]
util.hxx:334:82: note: ‘IDX2F’ declared here, later in the translation unit
I’ve googled around a bit for help on the template errors, but most of the solutions are focused on fixing the code. I’m presuming, for the moment, that Nvidia’s example code is fine. I’m wondering if I need to upgrade my gcc.
I’m on a Centos 8 system with the default gcc version 8.3.1 and CUDA toolkit version 11.3. According to Nvidia, this should be a fine setup.
Before I take the time to install a second gcc version in my home directory, I wonder if anyone has any advice for me?
Thanks for the help!
Hi, and welcome to the NVIDIA developer forums! You’ve posted your query to the CUDA-GDB forum. This forum is dedicated to the CUDA-GDB debugger. As your problem is related to compiling CUDA samples, I think you’ll have better luck if you ask your question in the CUDA Setup and Installation form.
Best of luck to you.
I will go ahead and move this to the CUDA Setup and Installation category for you.
Thank you! I can only imagine that the sugar high from my lunchtime cookie caused me to click on the wrong forum…
Okay, I figured this out … the example code was missing some directives. I added the following definitions to the top of both the main cpp file and the header:
#ifndef IDX2F
#endif /* IDX2F */
#ifndef IDX1F
#define IDX1F(i) ((i)-1)
#endif /* IDX1F */
#ifndef imin
#define imin( x, y ) ((x)<(y)) ? (x) : (y)
#endif
#ifndef imax
#define imax( x, y ) ((x)>(y)) ? (x) : (y)
#endif
