Compilation error with CUDA-9.0 installation
While trying to install CUDA-9.0 on my laptop I went through all necessary steps until samples compilation. The following error happened. See the output on screen:
ssn@ssn-ThinkPad-T460:~ nvcc -V nvcc: NVIDIA (R) Cuda compiler driver Copyright (c) 2005-2017 NVIDIA Corporation Built on Mon_Jun_26_16:13:28_CDT_2017 Cuda compilation tools, release 9.0, V9.0.102 ssn@ssn-ThinkPad-T460:~ ls /usr/local/cuda-9.0/samples
0_Simple 2_Graphics 4_Finance 6_Advanced common Makefile
1_Utilities 3_Imaging 5_Simulations 7_CUDALibraries EULA.txt
ssn@ssn-ThinkPad-T460:~ cd /usr/local/cuda-9.0/samples ssn@ssn-ThinkPad-T460:/usr/local/cuda-9.0/samples make
make[1]: вход в каталог «/usr/local/cuda-9.0/samples/0_Simple/vectorAdd_nvrtc»
g++ -I…/…/common/inc -I/usr/local/cuda-9.0/include -o vectorAdd.o -c vectorAdd.cpp
In file included from vectorAdd.cpp:30:0:
…/…/common/inc/nvrtc_helper.h: In function ‘void compileFileToPTX(char*, int, char**, char**, size_t*, int)’:
…/…/common/inc/nvrtc_helper.h:50:29: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
char *HeaderNames = “cooperative_groups.h”;
Assembler messages:
Fatal error: can’t create vectorAdd.o: Отказано в доступе
Makefile:301: ошибка выполнения рецепта для цели «vectorAdd.o»
make[1]: *** [vectorAdd.o] Ошибка 1
make[1]: выход из каталога «/usr/local/cuda-9.0/samples/0_Simple/vectorAdd_nvrtc»
Makefile:52: ошибка выполнения рецепта для цели «0_Simple/vectorAdd_nvrtc/Makefile.ph_build»
make: *** [0_Simple/vectorAdd_nvrtc/Makefile.ph_build] Ошибка 2
ssn@ssn-ThinkPad-T460:/usr/local/cuda-9.0/samples$ cd
ssn@ssn-ThinkPad-T460:~ lspci | grep -i nvidia 06:00.0 3D controller: NVIDIA Corporation GM108M [GeForce 940MX] (rev a2) ssn@ssn-ThinkPad-T460:~ uname -m && cat /etc/*release
x86_64
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=16.04
DISTRIB_CODENAME=xenial
DISTRIB_DESCRIPTION=“Ubuntu 16.04.2 LTS”
NAME=“Ubuntu”
VERSION=“16.04.2 LTS (Xenial Xerus)”
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME=“Ubuntu 16.04.2 LTS”
VERSION_ID=“16.04”
HOME_URL=“http://www.ubuntu.com/
SUPPORT_URL=“http://help.ubuntu.com/
BUG_REPORT_URL=“http://bugs.launchpad.net/ubuntu/
VERSION_CODENAME=xenial
UBUNTU_CODENAME=xenial
ssn@ssn-ThinkPad-T460:~$ gcc --version
Above and below the laptop’s configuration values are shown.
Any idea what’s going wrong and how to fix it?
Thanks in advance.
See also info to gcc version.
gcc (Ubuntu 5.4.0-6ubuntu1~16.04.4) 5.4.0 20160609
Copyright © 2015 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
