Hi everyone,
I am trying to compile a code using the PGI compiler and I get the following error on the MPI_get_address call: “PGF90-S-0155-Could not resolve generic procedure mpi_get_address”.
A MWE that can be used to reproduce the error is reported here below.
The compilation instruction I use is:
mpifort -O3 -lm -ldl test.f90 -o exec
I am trying to compile using pgi/19.4 and mpi/pgi_openmpi/19.4 (currently using the modules provided on bridges.psc.edu).
I have no clue why this is happening; in the complete code (not reported here) other calls to MPI subroutines/functions work just fine (MPI module is included correctly and works), the only error is on the MPI_get_address.
program test
use mpi
integer :: n,m
integer :: ierr
integer :: iadd
double precision, allocatable, asynchronous :: bufs(:,:)
n=10
m=30
allocate(bufs(n,m))
if(.not.mpi_async_protects_nonblocking) call mpi_get_address(bufs,iadd,ierr)
deallocate(bufs)
end program test
