I’m using OpenCL with a GTX 280 under Fedora 10. I’ve just upgraded to CUDA 3.1, and several of my kernels no longer compile. Here is the error log:
[codebox]ptxas application ptx input, line 492; fatal : Parsing error near ‘PHINODE’: syntax error
ptxas fatal : Ptx assembly aborted due to errors
error : Ptx compilation failed: gpu=‘sm_13’, device code=‘cuModuleLoadDataEx_5’
: Considering profile ‘compute_13’ for gpu=‘sm_13’ in ‘cuModuleLoadDataEx_5’
: Retrieving binary for ‘cuModuleLoadDataEx_5’, for gpu=‘sm_13’, usage mode=’ ’
: Control flags for ‘cuModuleLoadDataEx_5’ disable search path
: Ptx binary found for ‘cuModuleLoadDataEx_5’, architecture=‘compute_13’
: Ptx compilation for ‘cuModuleLoadDataEx_5’, for gpu=‘sm_13’, ocg options=’ '[/codebox]
The string “PHINODE” does not appear anywhere in my kernel, so that seems to be something internal to the compiler. Any idea what could be causing this, or what I could do about it?
Peter
