I use CUDA1.1 x64 under Windows2003 Server x64 and I got one strange error: if I build my project in MVS2005 and then run exe file evrything is ok, and if I use -run option from command line compilation evrything still works fine, but if I build my project from command line using -o -c options and then try execute it I get such error:
The program or feature **** cannot run or start due to incompatibility with 64-bit versions of windows...
Is there any new compiler option for x64 compilation under windows (I didn’t found it into nvcc 1.1 documentation)?
