Hi there,
I’m trying to build gstomx library from L4T 28.2.1 using the sources from: https://developer.nvidia.com/embedded/dlc/sources-r2821. I am running into an issue at the moment while building its dependency library, gstegl.
I’m following the steps from the README file:
- Untar the package and enter the dir
- ./configure
- make
- make install
and I have installed the installed the necessary prerequisites for this library with apt-get install.
This is my output when I run make:
Making all in po
make[2]: Entering directory '/home/nvidia/Downloads/public_release/gstegl_src/gst-egl/po'
make .pot-update
make[3]: Entering directory '/home/nvidia/Downloads/public_release/gstegl_src/gst-egl/po'
make[3]: *** No rule to make target '<b>../ext/gsettings/org.freedesktop.gstreamer.default-elements.gschema.xml.in</b>', needed by '.pot-update'. Stop.
make[3]: Leaving directory '/home/nvidia/Downloads/public_release/gstegl_src/gst-egl/po'
Makefile:252: recipe for target '.pot' failed
make[2]: *** [.pot] Error 2
make[2]: Leaving directory '/home/nvidia/Downloads/public_release/gstegl_src/gst-egl/po'
Makefile:713: recipe for target 'all-recursive' failed
Basically, the make fails while trying to compile bits from po folder.
When looking at the Makefile from po folder, it looks like the missing file is from gst-plugins-bad library.
Any idea on how to point the Makefile to the correct location in order to successfully build gstegl?
Thanks,
B.
