Compilation of Point Cloud Library on TX2 falied
I am trying to compile PCL from source on TX2 , But build fails every time… I am new to Tx2
So unsure of this error…
Here is complete build fail :
nvidia@tegra-ubuntu:~/pcl-pcl-1.8.1rc2/build$ make -j6
Scanning dependencies of target pcl_io_ply
Scanning dependencies of target pcl_common
Scanning dependencies of target pcl_octree
Scanning dependencies of target pcl_people
Scanning dependencies of target pcl_pcd_convert_NaN_nan
[ 0%] Building CXX object io/tools/CMakeFiles/pcl_pcd_convert_NaN_nan.dir/pcd_convert_NaN_nan.cpp.o
[ 0%] Building CXX object people/CMakeFiles/pcl_people.dir/src/hog.cpp.o
[ 0%] Building CXX object io/CMakeFiles/pcl_io_ply.dir/src/ply/ply_parser.cpp.o
[ 0%] Building CXX object octree/CMakeFiles/pcl_octree.dir/src/octree_inst.cpp.o
[ 0%] Building CXX object common/CMakeFiles/pcl_common.dir/src/pcl_base.cpp.o
[ 0%] Building CXX object common/CMakeFiles/pcl_common.dir/src/point_types.cpp.o
[ 1%] Linking CXX executable …/…/bin/pcl_pcd_convert_NaN_nan
[ 1%] Built target pcl_pcd_convert_NaN_nan
[ 1%] Building CXX object common/CMakeFiles/pcl_common.dir/src/io.cpp.o
[ 1%] Linking CXX shared library …/lib/libpcl_people.so
[ 1%] Built target pcl_people
[ 1%] Building CXX object common/CMakeFiles/pcl_common.dir/src/common.cpp.o
[ 2%] Building CXX object common/CMakeFiles/pcl_common.dir/src/correspondence.cpp.o
[ 2%] Building CXX object common/CMakeFiles/pcl_common.dir/src/distances.cpp.o
[ 2%] Building CXX object common/CMakeFiles/pcl_common.dir/src/parse.cpp.o
[ 2%] Building CXX object common/CMakeFiles/pcl_common.dir/src/poses_from_matches.cpp.o
[ 2%] Building CXX object common/CMakeFiles/pcl_common.dir/src/print.cpp.o
[ 3%] Building CXX object common/CMakeFiles/pcl_common.dir/src/projection_matrix.cpp.o
[ 3%] Building CXX object common/CMakeFiles/pcl_common.dir/src/time_trigger.cpp.o
[ 3%] Building CXX object common/CMakeFiles/pcl_common.dir/src/gaussian.cpp.o
[ 3%] Building CXX object common/CMakeFiles/pcl_common.dir/src/colors.cpp.o
[ 3%] Building CXX object common/CMakeFiles/pcl_common.dir/src/feature_histogram.cpp.o
[ 3%] Building CXX object common/CMakeFiles/pcl_common.dir/src/bearing_angle_image.cpp.o
[ 4%] Building CXX object common/CMakeFiles/pcl_common.dir/src/range_image.cpp.o
[ 4%] Building CXX object common/CMakeFiles/pcl_common.dir/src/range_image_planar.cpp.o
[ 4%] Building C object common/CMakeFiles/pcl_common.dir/src/fft/kiss_fft.c.o
[ 4%] Building C object common/CMakeFiles/pcl_common.dir/src/fft/kiss_fftr.c.o
[ 4%] Linking CXX shared library …/lib/libpcl_io_ply.so
[ 4%] Built target pcl_io_ply
Scanning dependencies of target pcl_ply2ply
Scanning dependencies of target pcl_plyheader
[ 4%] Building CXX object io/tools/ply/CMakeFiles/pcl_plyheader.dir/plyheader.cpp.o
[ 4%] Building CXX object io/tools/ply/CMakeFiles/pcl_ply2ply.dir/ply2ply.cpp.o
[ 4%] Linking CXX executable …/…/…/bin/pcl_plyheader
[ 4%] Built target pcl_plyheader
Scanning dependencies of target pcl_ply2raw
[ 4%] Building CXX object io/tools/ply/CMakeFiles/pcl_ply2raw.dir/ply2raw.cpp.o
Scanning dependencies of target pcl_ply2obj
[ 4%] Building CXX object io/tools/ply/CMakeFiles/pcl_ply2obj.dir/ply2obj.cpp.o
[ 4%] Linking CXX executable …/…/…/bin/pcl_ply2raw
[ 4%] Built target pcl_ply2raw
[ 4%] Linking CXX shared library …/lib/libpcl_common.so
[ 4%] Built target pcl_common
Scanning dependencies of target pcl_sample_consensus
Scanning dependencies of target pcl_kdtree
[ 5%] Building CXX object kdtree/CMakeFiles/pcl_kdtree.dir/src/kdtree_flann.cpp.o
[ 5%] Building CXX object sample_consensus/CMakeFiles/pcl_sample_consensus.dir/src/sac.cpp.o
[ 5%] Linking CXX executable …/…/…/bin/pcl_ply2ply
[ 5%] Built target pcl_ply2ply
[ 6%] Building CXX object sample_consensus/CMakeFiles/pcl_sample_consensus.dir/src/sac_model_circle.cpp.o
[ 6%] Building CXX object io/CMakeFiles/pcl_io.dir/src/debayer.cpp.o
[ 7%] Building CXX object io/CMakeFiles/pcl_io.dir/src/pcd_grabber.cpp.o
[ 7%] Linking CXX executable …/…/…/bin/pcl_ply2obj
[ 7%] Built target pcl_ply2obj
[ 7%] Building CXX object io/CMakeFiles/pcl_io.dir/src/pcd_io.cpp.o
In file included from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/include/pcl/sample_consensus/sac_model.h:52:0,
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/include/pcl/sample_consensus/sac.h:45,
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/include/pcl/sample_consensus/ransac.h:44,
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/include/pcl/sample_consensus/impl/ransac.hpp:44,
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/src/sac.cpp:38:
/home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/include/pcl/sample_consensus/model_types.h: In function ‘void __static_initialization_and_destruction_0(int, int)’:
/home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/include/pcl/sample_consensus/model_types.h:99:3: warning: ‘pcl::SAC_SAMPLE_SIZE’ is deprecated: This map is deprecated and is kept only to prevent breaking existing user code. Starting from PCL 1.8.0 model sample size is a protected member of the SampleConsensusModel class [-Wdeprecated-declarations]
SAC_SAMPLE_SIZE (sample_size_pairs, sample_size_pairs + sizeof (sample_size_pairs) / sizeof (SampleSizeModel));
/home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/include/pcl/sample_consensus/model_types.h:99:3: note: declared here
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/include/pcl/sample_consensus/sac_model_circle.h:44,
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/include/pcl/sample_consensus/impl/sac_model_circle.hpp:45,
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/src/sac_model_circle.cpp:39:
Scanning dependencies of target pcl_ml
[ 8%] Building CXX object ml/CMakeFiles/pcl_ml.dir/src/point_xy_32i.cpp.o
[ 8%] Building CXX object io/CMakeFiles/pcl_io.dir/src/vtk_io.cpp.o
[ 8%] Linking CXX shared library …/lib/libpcl_octree.so
[ 8%] Built target pcl_octree
[ 8%] Building CXX object io/CMakeFiles/pcl_io.dir/src/ply_io.cpp.o
[ 8%] Building CXX object ml/CMakeFiles/pcl_ml.dir/src/point_xy_32f.cpp.o
Scanning dependencies of target pcl_stereo
[ 8%] Building CXX object stereo/CMakeFiles/pcl_stereo.dir/src/stereo_grabber.cpp.o
[ 8%] Building CXX object ml/CMakeFiles/pcl_ml.dir/src/densecrf.cpp.o
[ 8%] Building CXX object stereo/CMakeFiles/pcl_stereo.dir/src/stereo_matching.cpp.o
[ 8%] Building CXX object stereo/CMakeFiles/pcl_stereo.dir/src/stereo_block_based.cpp.o
[ 8%] Building CXX object ml/CMakeFiles/pcl_ml.dir/src/pairwise_potential.cpp.o
[ 8%] Building CXX object sample_consensus/CMakeFiles/pcl_sample_consensus.dir/src/sac_model_circle3d.cpp.o
[ 8%] Building CXX object stereo/CMakeFiles/pcl_stereo.dir/src/stereo_adaptive_cost_so.cpp.o
[ 8%] Building CXX object ml/CMakeFiles/pcl_ml.dir/src/permutohedral.cpp.o
[ 8%] Building CXX object io/CMakeFiles/pcl_io.dir/src/ascii_io.cpp.o
[ 8%] Linking CXX shared library …/lib/libpcl_kdtree.so
[ 8%] Built target pcl_kdtree
[ 8%] Building CXX object io/CMakeFiles/pcl_io.dir/src/compression.cpp.o
[ 9%] Building CXX object io/CMakeFiles/pcl_io.dir/src/lzf.cpp.o
[ 10%] Building CXX object stereo/CMakeFiles/pcl_stereo.dir/src/disparity_map_converter.cpp.o
[ 10%] Building CXX object stereo/CMakeFiles/pcl_stereo.dir/src/digital_elevation_map.cpp.o
[ 10%] Building CXX object sample_consensus/CMakeFiles/pcl_sample_consensus.dir/src/sac_model_cylinder.cpp.o
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/include/pcl/sample_consensus/sac_model_circle3d.h:41,
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/include/pcl/sample_consensus/impl/sac_model_circle3d.hpp:43,
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/src/sac_model_circle3d.cpp:38:
[ 10%] Building CXX object ml/CMakeFiles/pcl_ml.dir/src/svm_wrapper.cpp.o
[ 10%] Linking CXX shared library …/lib/libpcl_stereo.so
[ 10%] Built target pcl_stereo
[ 10%] Building CXX object sample_consensus/CMakeFiles/pcl_sample_consensus.dir/src/sac_model_cone.cpp.o
[ 10%] Building CXX object sample_consensus/CMakeFiles/pcl_sample_consensus.dir/src/sac_model_line.cpp.o
[ 11%] Building CXX object ml/CMakeFiles/pcl_ml.dir/src/svm.cpp.o
[ 11%] Building CXX object ml/CMakeFiles/pcl_ml.dir/src/kmeans.cpp.o
[ 11%] Building CXX object io/CMakeFiles/pcl_io.dir/src/lzf_image_io.cpp.o
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/include/pcl/sample_consensus/sac_model_cylinder.h:44,
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/include/pcl/sample_consensus/impl/sac_model_cylinder.hpp:45,
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/src/sac_model_cylinder.cpp:39:
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/include/pcl/sample_consensus/sac_model_line.h:44,
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/include/pcl/sample_consensus/impl/sac_model_line.hpp:44,
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/src/sac_model_line.cpp:39:
[ 11%] Linking CXX shared library …/lib/libpcl_ml.so
[ 11%] Built target pcl_ml
[ 12%] Building CXX object sample_consensus/CMakeFiles/pcl_sample_consensus.dir/src/sac_model_parallel_line.cpp.o
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/include/pcl/sample_consensus/sac_model_cone.h:42,
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/include/pcl/sample_consensus/impl/sac_model_cone.hpp:43,
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/src/sac_model_cone.cpp:39:
[ 12%] Building CXX object io/CMakeFiles/pcl_io.dir/src/obj_io.cpp.o
Scanning dependencies of target pcl_search
[ 12%] Building CXX object search/CMakeFiles/pcl_search.dir/src/search.cpp.o
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/include/pcl/sample_consensus/sac_model_parallel_line.h:44,
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/include/pcl/sample_consensus/impl/sac_model_parallel_line.hpp:45,
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/src/sac_model_parallel_line.cpp:38:
[ 12%] Building CXX object io/CMakeFiles/pcl_io.dir/src/ifs_io.cpp.o
[ 12%] Building CXX object io/CMakeFiles/pcl_io.dir/src/image_grabber.cpp.o
[ 12%] Building CXX object sample_consensus/CMakeFiles/pcl_sample_consensus.dir/src/sac_model_stick.cpp.o
[ 12%] Building CXX object sample_consensus/CMakeFiles/pcl_sample_consensus.dir/src/sac_model_normal_parallel_plane.cpp.o
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/include/pcl/sample_consensus/sac_model_stick.h:44,
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/include/pcl/sample_consensus/impl/sac_model_stick.hpp:44,
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/src/sac_model_stick.cpp:40:
[ 12%] Building CXX object search/CMakeFiles/pcl_search.dir/src/kdtree.cpp.o
[ 13%] Building CXX object io/CMakeFiles/pcl_io.dir/src/hdl_grabber.cpp.o
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/include/pcl/sample_consensus/sac_model_normal_plane.h:44,
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/include/pcl/sample_consensus/sac_model_normal_parallel_plane.h:44,
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/include/pcl/sample_consensus/impl/sac_model_normal_parallel_plane.hpp:44,
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/src/sac_model_normal_parallel_plane.cpp:39:
[ 13%] Building CXX object io/CMakeFiles/pcl_io.dir/src/vlp_grabber.cpp.o
[ 14%] Building CXX object search/CMakeFiles/pcl_search.dir/src/brute_force.cpp.o
[ 14%] Building CXX object io/CMakeFiles/pcl_io.dir/src/robot_eye_grabber.cpp.o
[ 14%] Building CXX object search/CMakeFiles/pcl_search.dir/src/organized.cpp.o
[ 14%] Building CXX object io/CMakeFiles/pcl_io.dir/src/file_io.cpp.o
[ 14%] Building CXX object search/CMakeFiles/pcl_search.dir/src/octree.cpp.o
[ 14%] Building CXX object io/CMakeFiles/pcl_io.dir/src/auto_io.cpp.o
[ 15%] Building CXX object io/CMakeFiles/pcl_io.dir/src/io_exception.cpp.o
[ 15%] Building CXX object sample_consensus/CMakeFiles/pcl_sample_consensus.dir/src/sac_model_normal_plane.cpp.o
[ 15%] Building CXX object sample_consensus/CMakeFiles/pcl_sample_consensus.dir/src/sac_model_normal_sphere.cpp.o
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/include/pcl/sample_consensus/sac_model_normal_sphere.h:44,
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/include/pcl/sample_consensus/impl/sac_model_normal_sphere.hpp:44,
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/src/sac_model_normal_sphere.cpp:39:
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/include/pcl/sample_consensus/impl/sac_model_normal_plane.hpp:44,
from /home/nvidia/pcl-pcl-1.8.1rc2/sample_consensus/src/sac_model_normal_plane.cpp:39:
c++: internal compiler error: Killed (program cc1plus)
Please submit a full bug report,
with preprocessed source if appropriate.
See <file:///usr/share/doc/gcc-5/README.Bugs> for instructions.
sample_consensus/CMakeFiles/pcl_sample_consensus.dir/build.make:158: recipe for target ‘sample_consensus/CMakeFiles/pcl_sample_consensus.dir/src/sac_model_cone.cpp.o’ failed
make[2]: *** [sample_consensus/CMakeFiles/pcl_sample_consensus.dir/src/sac_model_cone.cpp.o] Error 4
make[2]: *** Waiting for unfinished jobs…
[ 15%] Building CXX object io/CMakeFiles/pcl_io.dir/src/vtk_lib_io.cpp.o
[ 15%] Building CXX object io/CMakeFiles/pcl_io.dir/src/png_io.cpp.o
[ 15%] Building CXX object io/CMakeFiles/pcl_io.dir/src/openni_camera/openni_device.cpp.o
[ 15%] Linking CXX shared library …/lib/libpcl_search.so
[ 15%] Built target pcl_search
[ 15%] Building CXX object io/CMakeFiles/pcl_io.dir/src/openni_camera/openni_device_primesense.cpp.o
Scanning dependencies of target pcl_surface
[ 15%] Building CXX object surface/CMakeFiles/pcl_surface.dir/src/processing.cpp.o
[ 15%] Building CXX object surface/CMakeFiles/pcl_surface.dir/src/ear_clipping.cpp.o
[ 16%] Building CXX object surface/CMakeFiles/pcl_surface.dir/src/gp3.cpp.o
[ 16%] Building CXX object io/CMakeFiles/pcl_io.dir/src/openni_camera/openni_image_bayer_grbg.cpp.o
[ 16%] Building CXX object surface/CMakeFiles/pcl_surface.dir/src/grid_projection.cpp.o
[ 17%] Building CXX object io/CMakeFiles/pcl_io.dir/src/openni_camera/openni_depth_image.cpp.o
[ 17%] Building CXX object surface/CMakeFiles/pcl_surface.dir/src/marching_cubes.cpp.o
[ 17%] Building CXX object io/CMakeFiles/pcl_io.dir/src/openni_camera/openni_ir_image.cpp.o
[ 17%] Building CXX object surface/CMakeFiles/pcl_surface.dir/src/marching_cubes_hoppe.cpp.o
[ 17%] Building CXX object io/CMakeFiles/pcl_io.dir/src/openni_camera/openni_device_kinect.cpp.o
[ 17%] Building CXX object io/CMakeFiles/pcl_io.dir/src/openni_camera/openni_device_xtion.cpp.o
[ 17%] Building CXX object io/CMakeFiles/pcl_io.dir/src/openni_camera/openni_device_oni.cpp.o
[ 18%] Building CXX object io/CMakeFiles/pcl_io.dir/src/openni_camera/openni_driver.cpp.o
CMakeFiles/Makefile2:952: recipe for target ‘sample_consensus/CMakeFiles/pcl_sample_consensus.dir/all’ failed
make[1]: *** [sample_consensus/CMakeFiles/pcl_sample_consensus.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs…
[ 18%] Building CXX object io/CMakeFiles/pcl_io.dir/src/openni_camera/openni_exception.cpp.o
[ 18%] Building CXX object surface/CMakeFiles/pcl_surface.dir/src/marching_cubes_rbf.cpp.o
[ 18%] Building CXX object surface/CMakeFiles/pcl_surface.dir/src/bilateral_upsampling.cpp.o
[ 18%] Building CXX object io/CMakeFiles/pcl_io.dir/src/openni_camera/openni_image_yuv_422.cpp.o
[ 19%] Building CXX object surface/CMakeFiles/pcl_surface.dir/src/mls.cpp.o
[ 19%] Building CXX object surface/CMakeFiles/pcl_surface.dir/src/organized_fast_mesh.cpp.o
[ 19%] Building CXX object surface/CMakeFiles/pcl_surface.dir/src/simplification_remove_unused_vertices.cpp.o
[ 19%] Building CXX object io/CMakeFiles/pcl_io.dir/src/openni_camera/openni_image_rgb24.cpp.o
[ 19%] Building CXX object io/CMakeFiles/pcl_io.dir/src/openni_grabber.cpp.o
[ 19%] Building CXX object surface/CMakeFiles/pcl_surface.dir/src/surfel_smoothing.cpp.o
[ 19%] Building CXX object surface/CMakeFiles/pcl_surface.dir/src/texture_mapping.cpp.o
[ 20%] Building CXX object io/CMakeFiles/pcl_io.dir/src/oni_grabber.cpp.o
[ 20%] Building CXX object io/CMakeFiles/pcl_io.dir/src/dinast_grabber.cpp.o
[ 21%] Building CXX object surface/CMakeFiles/pcl_surface.dir/src/vtk_smoothing/vtk_utils.cpp.o
[ 21%] Building CXX object surface/CMakeFiles/pcl_surface.dir/src/vtk_smoothing/vtk_mesh_subdivision.cpp.o
[ 21%] Building CXX object io/CMakeFiles/pcl_io.dir/src/libpng_wrapper.cpp.o
[ 21%] Building CXX object surface/CMakeFiles/pcl_surface.dir/src/vtk_smoothing/vtk_mesh_quadric_decimation.cpp.o
[ 21%] Building CXX object surface/CMakeFiles/pcl_surface.dir/src/vtk_smoothing/vtk_mesh_smoothing_laplacian.cpp.o
[ 21%] Building CXX object surface/CMakeFiles/pcl_surface.dir/src/vtk_smoothing/vtk_mesh_smoothing_windowed_sinc.cpp.o
[ 21%] Linking CXX shared library …/lib/libpcl_io.so
[ 22%] Building CXX object surface/CMakeFiles/pcl_surface.dir/src/poisson.cpp.o
[ 22%] Building CXX object surface/CMakeFiles/pcl_surface.dir/src/concave_hull.cpp.o
[ 22%] Built target pcl_io
[ 22%] Building CXX object surface/CMakeFiles/pcl_surface.dir/src/convex_hull.cpp.o
[ 22%] Building CXX object surface/CMakeFiles/pcl_surface.dir/src/3rdparty/poisson4/factor.cpp.o
[ 22%] Building CXX object surface/CMakeFiles/pcl_surface.dir/src/3rdparty/poisson4/geometry.cpp.o
[ 22%] Building CXX object surface/CMakeFiles/pcl_surface.dir/src/3rdparty/poisson4/marching_cubes_poisson.cpp.o
[ 23%] Linking CXX shared library …/lib/libpcl_surface.so
[ 23%] Built target pcl_surface
Makefile:162: recipe for target ‘all’ failed
make: *** [all] Error 2
any help is appreciated… thank you!!!
The error:
usually means that you ran out of memory. If you are running other programs, try closing those before compiling. If there are no running programs, then setting up a swap memory file area can help on the Jetson. Another option is to cross compile PCL on a PC.
https://www.youtube.com/watch?v=pmJsLYlCy0w
This tutorial is helpful to address this issue.
The other option you selected of cross compiling the PCL on PC is what I want to go ahead with as I want to do the development on host PC and cross compile the code using PCL and then run on the Tegra TX1 board.
But I am fairly new and in time crunch. Can you please help me with the procedure to cross compile PCL on PC for TX1
