dahu
June 15, 2007, 5:13pm
1
I have a code that compiles fine in emulation mode, but it does not compile if I want to execute it on the gpu.
The compilator complains that a shared variable is not declared.
I have something like this in my code :
template <class T, int size>
struct stack{
unsigned int n
T data;
__device__ __host__ void push(T t){data[n]=t; n++;}
__device__ __host__ T pop(){n--; return data[n];}
typedef struct
int somedata;
} foo;
__shared__ stack<foo, 10> fooStack[BLOCK_SIZE];
typedef struct
__device__ __host__ test()
foo myfoo;
fooStack[threadIdx.x].push(myfoo); // <- here the compiler complains that fooStack was not declared...
} bar;
my config :
8800 GTX, linux 32, cuda v0.9
thanks for your advice.
Stephane
perj
June 15, 2007, 8:50pm
2
struct stack{
unsigned int n
T data;
typedef struct
int somedata;
} foo;
typedef struct
foo myfoo;
} bar;
my config :
Stephane
[snapback]209856[/snapback]
I’m assuming this quite close to the entire (if not the entire kernel). I am curious if the scoping issues are completely different for using structs in a kernel. Try declaring your stack inside the struct. I just my group has run into similar problems with kernel execution in emulation mode compared to using the device.
dahu
June 15, 2007, 9:46pm
3
Thanks for the advice, but I think I found the error : I am trying to access shared mem in a function declared host , which is not allowed.
Stephane
