Hello
Refactoring a big code to remove fortran automatic array ( to avoid very costly reallocation on GPU )
… I’m trying to use a pool of generic global data , and the use only + => to rename the variable in a significant faction .
That work for CPU compilation, but not for GPU where the update clause doesn’t manage correctly the renaming .
All compiler concerned :
Compile for CPU :
pgf90 test_mirror_use_only.f90 -c
Compile for GPU
pgf90 -ta=nvidia test_mirror_use_only.f90 -c
PGF90-S-0038-Symbol, aa, has not been explicitly declared (test_mirror_use_only.f90: 10)
0 inform, 0 warnings, 1 severes, 0 fatal for use_aa_rename
Source :
MODULE MODD_DATA
IMPLICIT NONE
REAL , ALLOCATABLE, DIMENSION(:) :: AA
!$acc mirror(AA)
END MODULE MODD_DATA
SUBROUTINE USE_AA_RENAME()
USE MODD_DATA, ONLY : MYDATA => AA
IMPLICIT NONE
!$acc update host(MYDATA)
print*,"MYDATA=",MYDATA
END SUBROUTINE USE_AA_RENAME
REM : with “USE MODD_DATA, ONLY : AA , MYDATA => AA” the sample compile again but it could by a problem if multiple variable with the same name come from different modules ( we have this case on our code … )
A+
Juan
