I’m trying to run Linux on Xen. So I have to boot the board’s CPU in HYP mode instead of the default SVC mode.
Now I have a compiled u-boot from the upstreamed u-boot that can boot the CPU into HYP mode. However, the default L4T linux kernel cannot run on CPU with HYP mode. (It has to run on SVC mode as far as I can tell.)
So I want to compile a linux kernel that can run on HYP mode.
I used Jan Kiszka’s development tree - git.kiszka.org Git - linux.git/summary, branch queues/assorted which has some of the PSCI patches required to boot linux.
I enable the CONFIG_XEN and the PSCI config based on the .config file that was used for the NVIDIA L4T source code. I cross compile the source code on Ubuntu 12.04 and the device trees. I copied both the new compiled zImage and the new compiled dtb into the /boot folder on the board and add a new entry.
However, when I boot the board, I can tell that the new compiled kernel cannot boot at all. The system hangs after the message “Start Kernels…”
If I boot the CPU into SVC mode, I can boot into the original L4T kernel.
My question is:
Does anyone have a working Linux repo that can run on Jetson TK1 board with HYP mode?
If yes, could you share the .config file as well?
Thank you very much for your time and help in this question!
Yes. The linux kernel tree from Jan Kiszka’s development tree - git.kiszka.org Git - linux.git/summary, branch queues/assorted works for HYP mode. However, this kernel cannot boot as a dom0 in Xen environment… :-(
I’m wondering if anyone has ever succeed in boot a Linux in Xen or KVM?
