Compile and Flashing MPTCP Kernel to Jetson TX2
Hi Community,
I am a newbie in Jetson TX2
I just purchased Jetson TX2 developer Kit a couple of days ago.
Recently, I am working on a project which requires me to use the MPTCP kernel (http://multipath-tcp.org/).
Now, I wonder that if it is possible to flash this MPTCP kernel to the Jetson TX2.
I can compile the MPTCP kernel for arm architecture,
but I don’t know whether it is possible to use this kernel on my device.
Any response will be highly appreciated.
Thank you,
Made
I have never looked to see what is actually occurring, but this URL says there is direct support for Debian-based systems here:
http://multipath-tcp.org/pmwiki.php/Users/AptRepository
…however, it says:
<b>Note: only x86_64 packages are available.</b>
So maybe it is possible to build everything from source (and I am talking about what seems to be far more than just a kernel module). It isn’t unusual for a driver of this type to have some sort of architecture-dependent code, and although possibly it is just a recompile, chances are it won’t be “easy”.
Something to consider is that on a desktop PC it is likely more than one driver can service part of a network simultaneously to other drivers. On the TX2 only CPU0 can service hardware IRQs, and so I have doubts about performance even if you do get multiple networks running at the same time and behaving as a single interface. Failover for a redundant system would not be a problem, but adding several interfaces for the purpose of performance may not be a significant performance gain.
Hi Linuxdev,
Thank you for your response.
As you said, it may be too messy to build this kernel for the Jetson TX2.
Now, I am looking for another way for the project.
Thx
Hi dart_cly:
did you find another way for the project?
I also encountered similar problems, please give me some suggestions
