We are trying to compile and implement Yolo 5 ver 3.1 on Jetson Xavier NX / Jetpack 4.6 as per:
tensorrtx/yolov5 at master · wang-xinyu/tensorrtx · GitHub
However we end up with this error after running “make” step. Kindly any advice:
robotic@Asp-roboticnx:~/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/build$ make
[ 25%] Building NVCC (Device) object CMakeFiles/myplugins.dir/myplugins_generated_yololayer.cu.o
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.h(54): error: member function declared with “override” does not override a base class member
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.h(54): warning: function “nvinfer1::IPluginV2::enqueue(int32_t, const void *const *, void *const *, void *, cudaStream_t)” is hidden by “nvinfer1::YoloLayerPlugin::enqueue” – virtual function override intended?
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.h(85): warning: function “nvinfer1::IPluginV2Ext::configurePlugin(const nvinfer1::Dims *, int32_t, const nvinfer1::Dims *, int32_t, const nvinfer1::DataType *, const nvinfer1::DataType *, const __nv_bool *, const __nv_bool *, nvinfer1::PluginFormat, int32_t)” is hidden by “nvinfer1::YoloLayerPlugin::configurePlugin” – virtual function override intended?
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.h(87): error: exception specification for virtual function “nvinfer1::YoloLayerPlugin::detachFromContext” is incompatible with that of overridden function “nvinfer1::IPluginV2Ext::detachFromContext”
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.h(85): error: exception specification for virtual function “nvinfer1::YoloLayerPlugin::configurePlugin” is incompatible with that of overridden function “nvinfer1::IPluginV2IOExt::configurePlugin(const nvinfer1::PluginTensorDesc *, int32_t, const nvinfer1::PluginTensorDesc *, int32_t)”
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.h(82): error: exception specification for virtual function “nvinfer1::YoloLayerPlugin::attachToContext” is incompatible with that of overridden function “nvinfer1::IPluginV2Ext::attachToContext”
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.h(80): error: exception specification for virtual function “nvinfer1::YoloLayerPlugin::canBroadcastInputAcrossBatch” is incompatible with that of overridden function “nvinfer1::IPluginV2Ext::canBroadcastInputAcrossBatch”
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.h(78): error: exception specification for virtual function “nvinfer1::YoloLayerPlugin::isOutputBroadcastAcrossBatch” is incompatible with that of overridden function “nvinfer1::IPluginV2Ext::isOutputBroadcastAcrossBatch”
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.h(76): error: exception specification for virtual function “nvinfer1::YoloLayerPlugin::getOutputDataType” is incompatible with that of overridden function “nvinfer1::IPluginV2Ext::getOutputDataType”
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.h(74): error: exception specification for virtual function “nvinfer1::YoloLayerPlugin::getPluginNamespace” is incompatible with that of overridden function “nvinfer1::IPluginV2::getPluginNamespace”
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.h(72): error: exception specification for virtual function “nvinfer1::YoloLayerPlugin::setPluginNamespace” is incompatible with that of overridden function “nvinfer1::IPluginV2::setPluginNamespace”
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.h(70): error: exception specification for virtual function “nvinfer1::YoloLayerPlugin::clone” is incompatible with that of overridden function “nvinfer1::IPluginV2Ext::clone”
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.h(70): error: exception specification for virtual function “nvinfer1::YoloLayerPlugin::clone” is incompatible with that of overridden function “nvinfer1::IPluginV2::clone”
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.h(68): error: exception specification for virtual function “nvinfer1::YoloLayerPlugin::destroy” is incompatible with that of overridden function “nvinfer1::IPluginV2::destroy”
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.h(66): error: exception specification for virtual function “nvinfer1::YoloLayerPlugin::getPluginVersion” is incompatible with that of overridden function “nvinfer1::IPluginV2::getPluginVersion”
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.h(64): error: exception specification for virtual function “nvinfer1::YoloLayerPlugin::getPluginType” is incompatible with that of overridden function “nvinfer1::IPluginV2::getPluginType”
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.h(60): error: exception specification for virtual function “nvinfer1::YoloLayerPlugin::supportsFormatCombination” is incompatible with that of overridden function “nvinfer1::IPluginV2IOExt::supportsFormatCombination”
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.h(58): error: exception specification for virtual function “nvinfer1::YoloLayerPlugin::serialize” is incompatible with that of overridden function “nvinfer1::IPluginV2::serialize”
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.h(56): error: exception specification for virtual function “nvinfer1::YoloLayerPlugin::getSerializationSize” is incompatible with that of overridden function “nvinfer1::IPluginV2::getSerializationSize”
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.h(52): error: exception specification for virtual function “nvinfer1::YoloLayerPlugin::getWorkspaceSize” is incompatible with that of overridden function “nvinfer1::IPluginV2::getWorkspaceSize”
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.h(50): error: exception specification for virtual function “nvinfer1::YoloLayerPlugin::terminate” is incompatible with that of overridden function “nvinfer1::IPluginV2::terminate”
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.h(48): error: exception specification for virtual function “nvinfer1::YoloLayerPlugin::initialize” is incompatible with that of overridden function “nvinfer1::IPluginV2::initialize”
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.h(46): error: exception specification for virtual function “nvinfer1::YoloLayerPlugin::getOutputDimensions” is incompatible with that of overridden function “nvinfer1::IPluginV2::getOutputDimensions”
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.h(41): error: exception specification for virtual function “nvinfer1::YoloLayerPlugin::getNbOutputs” is incompatible with that of overridden function “nvinfer1::IPluginV2::getNbOutputs”
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.h(124): error: exception specification for virtual function “nvinfer1::YoloPluginCreator::getPluginNamespace” is incompatible with that of overridden function “nvinfer1::IPluginCreator::getPluginNamespace”
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.h(119): error: exception specification for virtual function “nvinfer1::YoloPluginCreator::setPluginNamespace” is incompatible with that of overridden function “nvinfer1::IPluginCreator::setPluginNamespace”
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.h(117): error: exception specification for virtual function “nvinfer1::YoloPluginCreator::deserializePlugin” is incompatible with that of overridden function “nvinfer1::IPluginCreator::deserializePlugin”
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.h(115): error: exception specification for virtual function “nvinfer1::YoloPluginCreator::createPlugin” is incompatible with that of overridden function “nvinfer1::IPluginCreator::createPlugin”
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.h(113): error: exception specification for virtual function “nvinfer1::YoloPluginCreator::getFieldNames” is incompatible with that of overridden function “nvinfer1::IPluginCreator::getFieldNames”
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.h(111): error: exception specification for virtual function “nvinfer1::YoloPluginCreator::getPluginVersion” is incompatible with that of overridden function “nvinfer1::IPluginCreator::getPluginVersion”
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.h(109): error: exception specification for virtual function “nvinfer1::YoloPluginCreator::getPluginName” is incompatible with that of overridden function “nvinfer1::IPluginCreator::getPluginName”
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/utils.h(41): error: exception specification for virtual function “Tn::Profiler::reportLayerTime” is incompatible with that of overridden function “nvinfer1::IProfiler::reportLayerTime”
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/utils.h(60): error: exception specification for virtual function “Tn::Logger::log” is incompatible with that of overridden function “nvinfer1::ILogger::log”
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.cu(156): error: object of abstract class type “nvinfer1::YoloLayerPlugin” is not allowed:
pure virtual function “nvinfer1::IPluginV2::enqueue” has no overrider
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.cu(299): error: object of abstract class type “nvinfer1::YoloLayerPlugin” is not allowed:
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/yololayer.cu(308): error: object of abstract class type “nvinfer1::YoloLayerPlugin” is not allowed:
34 errors detected in the compilation of “/tmp/tmpxft_00002fb8_00000000-6_yololayer.cpp1.ii”.
CMake Error at myplugins_generated_yololayer.cu.o.Debug.cmake:280 (message):
Error generating file
/home/robotic/YOLO_5_ver_1_6/TensorRT_3.1_old/tensorrtx-yolov5-v3.1/yolov5/build/CMakeFiles/myplugins.dir//./myplugins_generated_yololayer.cu.o
CMakeFiles/myplugins.dir/build.make:75: recipe for target ‘CMakeFiles/myplugins.dir/myplugins_generated_yololayer.cu.o’ failed
make[2]: *** [CMakeFiles/myplugins.dir/myplugins_generated_yololayer.cu.o] Error 1
CMakeFiles/Makefile2:84: recipe for target ‘CMakeFiles/myplugins.dir/all’ failed
make[1]: *** [CMakeFiles/myplugins.dir/all] Error 2
Makefile:90: recipe for target ‘all’ failed
make: *** [all] Error 2
