hi,
because of using Vector of C++, i have to compile the file deepstream_app_config_parser.c by cpp.
but because of this warning to get my application which can not work well.
pls help to check how to modify the file?
thank you very much!
hi,
• DeepStream Version
• TensorRT Version
jetson nx and jetpack4.6.
thanks
hi,
not that warning problem, and i have got correct result of face embedding with json.
it works super well with all other objects together.
pls ignore this topic,
thank you
