compile error for libctl
I am trying to compile libctl and get a
PGC-S-0000-Internal compiler error. copy_elem, unexp. dt 17 (cintegrator.c: 601)
pgcc-Fatal-/opt/pgi/linux86-64/7.1-6/bin/pgc TERMINATED by signal 11
DEPDIR=.deps depmode=none /bin/sh …/depcomp
/bin/sh …/libtool --tag=CC --mode=compile /opt/pgi/linux86-64/7.1-6/bin/pgcc -DHAVE_CONFIG_H -I. -I… -I~/mpb-1.4.2/include -I~/mpb-1.4.2/include -L~/mpb-1.4.2/lib -c -o cintegrator.lo cintegrator.c
/opt/pgi/linux86-64/7.1-6/bin/pgcc -DHAVE_CONFIG_H -I. -I… -I~/mpb-1.4.2/include -I~/mpb-1.4.2/include -L~/mpb-1.4.2/lib -c cintegrator.c -o cintegrator.o
Arguments to /opt/pgi/linux86-64/7.1-6/bin/pgc
/opt/pgi/linux86-64/7.1-6/bin/pgc cintegrator.c -opt 1 -terse 1 -inform warn -x 119 0xa10000 -x 122 0x40 -x 123 0x1000 -x 127 4 -x 127 17 -x 19 0x400000 -x 28 0x40000 -x 70 0x8000 -x 122 1 -quad -x 59 4 -x 59 4 -tp k8-64e -astype 0 -stdinc /opt/pgi/linux86-64/7.1-6/include:/usr/local/include:/usr/lib/gcc/x86_64-redhat-linux/4.1.2/include:/usr/lib/gcc/x86_64-redhat-linux/4.1.2/include:/usr/include -def unix -def __unix -def unix -def linux -def __linux -def linux -def __NO_MATH_INLINES -def x86_64 -def LONG_MAX=9223372036854775807L -def ‘SIZE_TYPE=unsigned long int’ -def ‘PTRDIFF_TYPE=long int’ -def __THROW= -def extension= -def amd64 -def SSE -def MMX -def SSE2 -def SSE3 -predicate ‘#machine(x86_64) #lint(off) #system(posix) #cpu(x86_64)’ -idir . -idir … -idir ~/mpb-1.4.2/include -idir ~/mpb-1.4.2/include -def HAVE_CONFIG_H -cmdline ‘+pgcc cintegrator.c -DHAVE_CONFIG_H -I. -I… -I~/mpb-1.4.2/include -I~/mpb-1.4.2/include -L~/mpb-1.4.2/lib -c -o cintegrator.o’ -outfile cintegrator.o -x 123 4 -x 2 0x400 -x 123 0x80000000 -alwaysinline /opt/pgi/linux86-64/7.1-6/lib/libintrinsics.il 4 -x 120 0x200000 -asm /tmp/pgccA8SotAwRhNW.s
I am glad for any hint!
Would it be possible for you to send us a small test case that gives that same error? This looks like a compiler bug. Please send to trs@pgroup.com.
Thank you,
Hongyon
