Compile Error Message
Hi I get the compile error below when I try to increase the number of parameters of a kernel function. The parameters are of type “Double *”.
"error PRJ0019: A tool returned an error code from “Compiling with CUDA Build Rule…”
I even try to put these parameters as the member of a struct to enalbe Struct of Array to reduce the number of parameters, but when the number of struct member increase, the same exception message comes out.
Any ideas?
Any ideas?
